Radioflyer
To my way of thinking, an engine hour is Tach Time of the bottom end or heart of the engine. The top end, typically cylinders, are more fungible. I think tach time is ideally more representative of actual engine wear and use. One can also consider Hobbs Time, which is usually some variable percentage (normally ~ 15% ?) higher, but doesn’t reflect relative idle vs high speed use. An engine hour is really not an absolute thing, right? Under ideal service conditions, engine hours can be a useful metric, but in real life…often not. Nevertheless, people often talk about engine hours (especially published TBO) as an absolute thing. Incidentally, I’ve looked at logs with tach and Hobbs used interchangeably.
A 300 tach hour engine has sat for 5 years with only an occasional brief run. That good sounding time is irrelevant, except for hope, with respect to condition. If an engine is opened for inspection after a prop strike, no defects found, and returned to service, it still retains the original service time… legally. To my mind, because of infant mortality or enhanced plastic strain, service time is now not so helpful. Simpler case - if an X time engine has all cylinders overhauled or replaced with (new or used) some hours later, time is still just X, but the number doesn’t reflect the improvement unless you study the logs.
Sorry for the rant, but I’m out of time.
