Vertical power support
Looks like the website is "Access Forbidden" as of today.
It isn't clear to me how much re configuration one can do without the online "configurator".
This box is basically a MOSFET multichannel switch with configurable current limits. Anyone interested in an alternative?
A 3 thousand dollar write off. Dang. Funny how the website dependence was designed in to force instantaneous product obsolescence.
I didn't realize Vertical Power had an online configurator. I configure my VPX locally with no internet connection. I realize their website is down as I write this. My guess is they either pushed out a bad website update or they have an expired certificate. Who knows? Not needed to update the VPX so no biggie.
Hmm... I only used the online "configurator" online load planning tool as a planning tool. I used the Windows PC based Configurator app on my laptop and connected to the VP-X directly via Ethernet to do the actual configuration. I thought that was how it was supposed to be done.
If someone is DITW because they don't have the Windows PC based app, I think I might be able to send you a copy.
That's how I do it.
The online planner is not required to configure the VP-X; it is meant to help you plan. You can do that manually, too, with a piece of paper and a pen if you prefer.
Sounds like a temporary website issue with a workaround identified by the fine folks here on VAF.
Onward!
Website is still offline. Not a good sign. Astronics, their parent doesn't even mention Vertical Power on their website.
Hopefully they're not out of business. Last I talked to them they were working on a new box with more circuits - that was a long time back though.
Hey everyone, sorry for the delay in responding to this...our website got hacked on July 3rd and our IT department has been working on restoring this week. It should be back up today. No worries about the product line, still going strong and we'll be at Oshkosh. As is already known, the planner site was not affected.
Hello, today is July 12, 2026 any idea when the website will be up and running I’m looking for the installation manual for both the PPS and VPX pro Thanks
Anyone that needs manuals, please email me at [email protected] and I'll send directly. Website should be back up this week. It has been modernized on the back end and our IT guys are confident we'll have it back up this week.
Thanks everyone. I've finally figured out what most of you already know. I started with the online tool and kind of got stuck in that mode. So far, so good. Lights, flaps, and trims are working nice!
For those about to purchase a VPX unit, is there any possibility of a new product launch in the coming months?
So, what's not to like about the existing unit/s ? They've been solid for the last ~13 years & the software hasn't changed in that time (very few, if any, avionics manufacturers can make that claim).
It's a remote box so making it more pretty won't make a difference to your panel - it is a remote box .
What feature would you want/need that isn't already catered for ?
From my observation all wishful 'features' usually come at a cost.
jakej
jakej
I kind of agree here. I'd not want to beta test a new product unless it gave a substantial benefit. I can't think of much I'd put on my VPX wish list, except whatever additional hardware redundancy they could cook up? Edit: also maybe a few more channels?
jakej
I totally agree. KELLI GIRL has flown 2200 Hobbs hours in 11 years with VPX. Not one hiccup. Very dependable. Very adjustable.
The only thing on my VPX wish list is the ability to toggle the landing/taxi lights' wigwag on and off, selecting either solid lights or wigwag while in flight.
Scroll - There is a way to do all that with 1 switch similar to what I’ve been doing with installs using a DPDT on-on-on switch.
On = LAND LTS & TAXI LT however Land Lts are set to Wig/Wag (automatically) above say 100 kts or your choice of speed.
On = TAXI LT only
OFF = All off
I also use the same on another switch for -
On = Nav/Strobe Lts
On = Nav Lts only
OFF = All off
The advantage of the above methodology is-
Reduces number of switches, less is better & more room if needed for other things. Using this method & keeping the switches on the far left hand side allowed me to install a 12” EFIS into an RV7 panel with room for another screen & avionics. YMMV 😉.
