IO-360 - All 4 EGTs/CHTs oscillating together, slight roughness. Looking for ideas.
Cwarkenton
Hi everyone,
I'm hoping to get some ideas before taking the airplane back to my shop.
Airplane
Van's RV-7
Lycoming IO-360 (parallel valve)
Hartzell constant-speed prop
Dynon HDX EMS
Slick magnetos
History
This issue originally started several months ago when the manifold pressure sensing line to the Dynon manifold pressure sensor broke.
The line was repaired and issue was remedied.
Now the airplane just came out of annual, during which the shop:
Installed new spark plugs
Installed a new ignition harness
Relocated the Dynon manifold pressure sensor from inside the cabin to the engine side of the firewall
Completed the annual inspection and other miscellaneous maintenance
Unfortunately, the original symptom is still present.
Symptoms
Slight but noticeable engine roughness in cruise when event occurs.
All four EGTs and CHTs oscillate together rather than one cylinder acting independently.
MAP and RPM appear very stable.
Fuel flow appears to fluctuate slightly (around 0.1 GPH), although I'm not sure whether that's significant.
Dynon will occasionally switch between displaying ROP and PK, even though I'm indicating approximately 50-80°F ROP.
GAMI spread is approximately 0.44 GPH.
CHTs otherwise look healthy and fairly even.
Engine starts well and appears to make normal power.
Separate electrical issue
Also after the annual, I'm now seeing charging voltage fluctuate between about 14.5 and 15.0 volts. This was not occurring before the annual. My shop believes the alternator's internal voltage regulator is failing, and we've already ordered a replacement B&C alternator.
I don't know if this is completely unrelated or if electrical noise could somehow be contributing to what I'm seeing on the EMS, but I thought it was worth mentioning.
I attached in a video in below comment.
Questions
Has anyone seen all four cylinders oscillate together?
Could this still be related to the manifold pressure sensing system or relocating the sensor?
Does this point more toward ignition timing, fuel servo, induction, or something else?
Could a failing alternator/regulator contribute to this behavior, or is that likely an unrelated issue being that originally the event occurred from a broken MP line?
Thanks in advance. Any ideas or troubleshooting suggestions are greatly appreciated.
CHTs simply don't move that fast. You have an indication issue.
Thanks! This was my first thought as well however there is slight but noticeable roughness when the oscillation occur.
Originally thought you put 'induction' issue which is kinda what I'm thinking but I am very inexperienced in engine issues.
well, there certainly could be something else going on as well, but whatever that is, it is not causing the chts to bounce like that. Do you have elec ignition? A systemic power or ground issue could be messing with that as well and creating the roughness.
The Dynon EMS indication of ROP, PK or LOP reflects a software model of your engine, not reality. It tends to be close, good enough for ball park stuff, not good enough as an analysis tool. As others have noted it seems you have indication problems, so inputs to this software model are now suspect as well.
With a GAMI spread of 0.44 and you running that low in the ROP range I’d guess you may have one or more cylinders LOP while others are ROP. This may explain your engine roughness. The preferred options it to reduce the GAMI spread to 0.0 - 0.1 GPH. This is not hard. I suggest that you never put a bigger nozzle in the lean cylinder(s), aways approach this by going smaller in the rich cylinder(s). My experince is 1 or 2 nozzle changes over 3-4 data runs and you are done. Don Rivera at AFP will help if you call him. I also recommend not spending money on GAMI nozzles.
Don't like the fluctuating voltage. possible that is the source of moving chts if it is adding interference on the bus, but don't really see how that could create roughness with slick mags.
any chance the roughness is the alternator loading up and letting go in oscillation?
....maybe....
If the OP had a hand held O-scope, configured correctly (AC coupled), I'll bet the mains look as "rough as a corn cob" (lots of AC transients riding on top of the DC).
+1 for the Alternator - Regulator, secondarily look at the rectifier - one or more failed?
Thanks you guys! I'm getting some good info and I appreciate it!
A note I should have included is that the oscillation event seems sporadic. At times everything it runs completely steady then it seems to randomly happen which is why I know there is a slight roughness. I feel a different vibration at my feet, check the monitor and sure enough everything is reading sporadically.
given that the roughness appears with the fluctuating voltage and other indication anomolies, i would start by sorting out the charging system first. start with the easy stuff, maybe loose wires on alt (pp has major issues with that), engine grd strap, etc.
....maybe....
i was thinking that a loose wire on the sense side could causing the alt to intermittenly go full output, then back off. could see how the inexperienced could view that as slight roughness. the rouighness tracking with weird indication issues makes this possible, as there is not many other ways for elec issues to cause roughness with mags.
If engine data recordings are available, we might be better able to determine cause-and-effect. Eg, if variations in the alternator voltage don't line up timewise with anything, we would look elsewhere.
Thank you all for the replies! I'm going to check all wiring and grounds over the weekend. That sounds like the consensus. Will report back!
Let's tease this out -- assuming it's a Hartzell/Plane Power with the 3 pin plug (Plug Code 312 - S, Ig, L), the "sense" wire is 1/2" long jumper between pins 1 - 2. The sense voltage is derived from the IG wire (aka Field, Alt Field, etc.) from the buss and is used to regulate the duty cycle of the rotor field current to maintain the output at 14.6V (or thereabouts).
Given the small mass of the sense "jumper" it's not likely to resonate its way to failure. However, it could be the IG wire that's going intermittent -- that would cause the Alternator Field to turn off, turn on, etc. (the field loads down the engine -- consumes a few mHP). In worse case terms, the alternator putting out 14.6V and the field at 5A (100% duty cycle) is going to "rob" .098HP, .06lbs/ft at the alternator pulley => ~0.211lbs/ft at the propellor.
I don't think normal human could perceive that difference ( 0.072% change).
...and to your point, it won't translate and be seen on the EFIS/EMS that quickly.
...and in the above example, the voltage would not rise, it would drop during the events as the alternator output would shut off...
If everything works, goes in for maintenance, and comes back with problems, the shop caused the problems and should fix them.
This is exactly the reason to do ones own maintenance on EAB planes. I beseech thee to take the LSRM/A 15 day class and DIY.
Truth
I vote for a mechanical problem with the alternator--specifically the SRE bearing being loose in the housing, like @DanH et al have had in the past. That could explain the electrical anomalies as well as the perceived engine roughness with the rotor bouncing around in the housing. As to why the roughness comes and goes, maybe that's due to how the rotor mostly self-aligns? Also check belt condition and tension. And for cracked alternator bracketry.
And other things to check: ensure a good ground cable from the engine to the airframe-- pull hard on the crimped connections and check bolt torque. And the regulator plug as @bjdecker said--one or more of the wires could be cracked in the terminal housing.
A bad ground between the engine and airframe can cause both these problems. It will cause the alternator to act flaky (voltage high) because it is seeing resistance in that line - and as a result of that resistance your engine is a "floating ground" at some slightly higher than zero potential relative to the rest of the airplane. This "extra voltage" also registers on thermocouples such as your CHT and EGT probe as an error that comes and goes with the alternator regulator raising and lowering the field current on the alternator.
Go fly - settle down to cruise conditions - and pull the field breaker on your alternator. If the CHT/EGT indications settle down to normal, guaranteed you have a flaky ground connection between the engine and airframe. Restore the field current and watch your temp jump, if you really want to be sure.
In my experience, the vast majority of thermocouples are two wire. Those don’t use a ground at the sensor. Can hang them in the air and they read correctly
Actually, ALL thermocouples (TC) are two-wire. However, some TC's are grounded at the sensing tip and others are floating, and most of ours are grounded. So, yes, they will read when "hanging in the air", but they can also pick up electrical noise since the junction is grounded.
TC info: https://alcoraero.com/wp-content/uploads/2023/01/Alcor®-Types-of-Thermocouples.pdf
Follow up resolution for archives. Voltage regulator was failing in the Plane Power alternator at just about 900 hours. Our best guess is electrical noise (I'm sure there's a real term) caused the erratic readings.
Replaced with a BNC and issue is remedied and I don't know if it's just in my head, but engine seems to produce better, smoother power as well.
Thanks again to all who contributed to troubleshooting!
