150 hours dual emags on IO390 in RV8. started with a "stumble" at low RPMs and not noticeable at higher RPMs, now noticeable. I think my left mag is not running internally. Here is my check:
Grounded the right mag at 1200 rpm, killed internal power on left mag and rpm went to zero and engine quit.
Grounded the left mag at 1200 rpm, killed internal power on right mag and rpm was steady and engine remained running.
My plan is to remove both mags for service. But at 150 hours???
I did a pull test on wires and all are attached, cleaned injectors, no change, plugs have 25 hours on them (issue started before new plugs)
Anything else I should check before I take them off?
