True, but it won't satisfy the requirements for a DAR or FSDO to issue an AWC.i think that wording applied before gps was ever invented. if you know [and you should] the magnetic deviation where you are flying...well, there you go.
The problem comes when some ill-informed inspector believes that you HAVE to have a "wet compass" despite your EFIS and its own magnetic direction indicator...
NoI should have asked if I need one legally for my inspection
Not so! It DOES satisfy the requirements for a DAR or a properly informed FSDO. First off, for daytime VFR, NO instruments are required as part 205 does not apply to experimental aircraft. And your Op Lims will clearly state that for night and/or IFR, you must meet the requirements of part 205 wich uses the term "magnetic direction indicator". It says nothing about the indicator being independent.True, but it won't satisfy the requirements for a DAR or FSDO to issue an AWC.
my fsdo guy would simply not accept it; he demanded a compass. Showed him the wording and he said "yes, mag dir indicator means compass; no compass, no awc." I just installed a cheap one, as it wasn't worth the consequences of arguing with him.Not so! It DOES satisfy the requirements for a DAR or a properly informed FSDO. First off, for daytime VFR, NO instruments are required as part 205 does not apply to experimental aircraft. And your Op Lims will clearly state that for night and/or IFR, you must meet the requirements of part 205 wich uses the term "magnetic direction indicator". It says nothing about the indicator being independent.
And….he was wrong, becaue as Mel noted above, NOTHIGN is required for DVFR ops. The first sentence of 91.205 starts with “For aircraft with a Standard Airworthiness Certificate…..” You have a “Special” Airworthiness, so it doesn’t apply unless called out by your ops Lims (as it does for night or IFR).my fsdo guy would simply not accept it; he demanded a compass. Showed him the wording and he said "yes, mag dir indicator means compass; no compass, no awc." I just installed a cheap one, as it wasn't worth the consequences of arguing with him.
He was 100% incorrect.my fsdo guy would simply not accept it; he demanded a compass. Showed him the wording and he said "yes, mag dir indicator means compass; no compass, no awc." I just installed a cheap one, as it wasn't worth the consequences of arguing with him.
If I get the inspector I think im getting, ive known him for 20+ years and hes a good guy. Hes inspected a bunch of rvs around here so.....hopefully hes still a good guyIn my experiences with the FSDO, I’ve found that they are jacks of all trades, not necessarily experts on EAB. But they are usually reasonable (although not always), and willing to be politely educated. Show them the comments from the DARs, above. Politely remind them that they are only certifying for phase 1, day, vfr only, where 91.205 does not apply. Later, you will self-certify for phase 2. If they persist, well, your choice to give in or fight.
Yeah, I missed that for VFR only aircraft. I tend to think in terms of IFR capable. My mistake.Not so! It DOES satisfy the requirements for a DAR or a properly informed FSDO. First off, for daytime VFR, NO instruments are required as part 205 does not apply to experimental aircraft. And your Op Lims will clearly state that for night and/or IFR, you must meet the requirements of part 205 wich uses the term "magnetic direction indicator". It says nothing about the indicator being independent.
You can argue down that rabbit hole if you choose. I have learned that proving the guy holding all the cards wrong rarely works out well. Cost $20 for a heap compass and everyone walked away happy.Ask him to show you the reg that says "wet compass required".
I'm guessing he will not be able to.
And no, magnetic direction indicator does not equal wet compass.
FAR 91.205 clearly states "magnetic direction indicator". Your EFIS will have that and it will show your heading (magnetic). AHARS has a built in magnetometer but you can also have a remote magnetometer like Dynon provides. Even they call it a "remote compass".
In my case, i had requested the paragraphs for night and ifr. Was unsure if the MDI is required for awc, but in my case the fsdo guy was clear in his mind that it was. I was prepared for the mdi vs compass argument, but not for the awc vs ifr regs. I didn’t understand at the time that the compass was not required for day only and therefore shouldn’t have had to have one untill i was ready for IFR flight.And….he was wrong, becaue as Mel noted above, NOTHIGN is required for DVFR ops. The first sentence of 91.205 starts with “For aircraft with a Standard Airworthiness Certificate…..” You have a “Special” Airworthiness, so it doesn’t apply unless called out by your ops Lims (as it does for night or IFR).
It was 10 years ago for me, so have no idea what they do now. Back then, the fsdo guys told me that if I didn't request IFR or night paragraphs, I wouldn't get them in thr op lims. would be great if that has changed.I see all kinds of posts where people ask for/request certain paragraphs for their new Op Lims.
Fact is when you obtain new Op Lims, you get the current revision.
They are pretty much "canned". You don't get to pick & choose what you want or don't want.
Then those FSDO Guys were wrong. This procedure has always been the rule, at least as long as I've been doing it since back in the last century.It was 10 years ago for me, so have no idea what they do now. Back then, the fsdo guys told me that if I didn't request IFR or night paragraphs, I wouldn't get them.
