PCU5000X and bracket from Showplanes. I had the governor set up to range from 10-2 o'clock with clockwise decrease. My rational is that I wanted a straight path across the top of the push rod tubes for my cable. I can pass the fuel line from spider to cylinder thru the bracket. As is, I have a cable and fuel line interference issue because of the bracket geometry and the way I had the governor set up. Thought I had it figured out, Ha! My query to the smarter ones is this: I figure I have three options here: (1) Have the PCU set up differently, but that = $$ and I have to send it out. (2) Modify the bracket to reposition the cable pass thru a bit higher via cutting and welding to eliminate the interference... that seems "doable" to me. (3) Reposition the fuel line somehow and leave the bracket unmolested. I do not know if that is possible or acceptable for any reason. If I could take it over the top of the bracket and keep it secured appropriately, is that a real possibility. Looking for any ideas, thoughts, or suggestions. Thanks so much!!
