I’m an IA!
glenadavis
I took the 16 hour course so now I can do my own conditional inspection on my RV – 12. Pretty scary considering how little I know. I do have an AxP looking over my shoulder. I removed my upper and lower cowlings today for the first time. I noticed that the lower cowling has what appears to be some insulation I assume to protect a cowling from melting. In fact, it appears the insulation itself has melted or at least is disintegrating. I’ve included a photo. Can anyone tell me what this material is actually for and where I buy it and any tips on replacing it. Thank you.
I would look at the source of the heat first. Then deal with the potential damage to the cowl. AntiSplat makes some really nice exhaust heat deflectors. If you need a good start on a Condition Inspection Word doc, shoot me an e-mail address.
First lesson...... It's "Condition" Inspection.
I wasn't sure what material you were asking about. The foil is sold by Vans in sheets. It really should have a layer of Fiberfrax between to protect the fiberglass.
It appears the fiberglass is bare. I would strip it all down and apply two coats of epoxy neat (no thinner) then a couple coats of epoxy primer. Then reapply the foil with Fiberfrax (1/16-1/8").
And us certified "IA's" are soon going to be "IR's"...but that's a whole different story... It is however, another reduction of FAA touch labor.
I would consider it to be a layer of carbon or soot. Exhaust leak or spilled oil? What does it look like after you have cleaned it off? That is right where the oil cooler sits, no?
That looks like a serious exhaust leak on the #2 header. There was a service bulletin (SB-00005) regarding potential cracking of cylinder #2 exhaust on the original RV12. If the header is cracked, there is a kit available from Vans to replace it; see the SB.
