Dynon Previews Integrated IFR GPS Navigation Capability for SkyView HDX
Dynon
Advertiser
Next-generation capability is in development to bring full IFR GPS navigation, including coupled LPV approaches, directly to the SkyView HDX platform with zero additional panel space required.
Dynon is excited to announce the development of a revolutionary leap forward for the light general aviation market: integrated IFR GPS navigation for the industry-leading SkyView HDX avionics system. This capability is being developed for simultaneous release across both Dynon Certified and experimental SkyView HDX product lines.
Historically, aircraft builders and retrofitters looking for full Instrument Flight Rules (IFR) capabilities were forced to install expensive external navigators into their radio stack. Dynon is shattering that paradigm by integrating full next-generation IFR navigation directly into the SkyView HDX system.
"Our goal has always been to make world-class avionics accessible, integrated, and intuitive," said Brad Thurow, President of Dynon. "With this upcoming capability, we intend for SkyView HDX owners to fly IFR missions, including coupled LPV approaches, without sacrificing a single inch of valuable radio stack panel space."
Simplicity by Design: Redefined Flight Planning
Beyond the hardware and integration breakthrough, Dynon will introduce a completely redesigned, ultra-intuitive flight planning interface built directly into the SkyView HDX software. While most IFR navigators often feel like operating decades-old Flight Management Systems (FMS) that require specialized training courses just to enter a route, Dynon's next-gen flight planner brings modern simplicity to the cockpit.
The flight planner seamlessly handles both VFR and complex IFR scenarios with effortless ease, serving as a steadfast ally in the cockpit that simplifies even the most demanding flight phases. Pilots will intuitively load departures, arrivals, and approaches using clear, visual workflows, entirely eliminating the steep learning curves historically associated with instrument flight transitions.
Ultimate Panel Flexibility & Lower Cost of Ownership
For existing SkyView HDX owners, the upgrade path will be incredibly simple. The underlying IFR capability will be delivered by a new, remote-mounted IFR module, bringing the capability into SkyView's on-screen flight planner. This solution utilizes the same proven modular architecture found across the existing SkyView product family and mounts completely behind the instrument panel. This leaves radio stacks perfectly clean, creating space for larger displays, additional radios, or storage.
Key Product Highlights:
  • Full IFR Capabilities, including LPV Approaches: Supports RNAV approaches down to LPV minimums, providing both horizontal and vertical guidance.
  • Zero Panel Space Required: Remote-mounted module keeps the radio stack wide open, allowing for cleaner panels and more flexible aircraft design.
  • Intuitive Next-Gen Flight Planner: A clean sheet design built to handle IFR and VFR scenarios seamlessly. Easily load departures, arrivals, and approaches with ease, eliminating the need for complex legacy training courses.
  • MOSAIC-Ready Integration: Designed perfectly for the next generation of aircraft. The new MOSAIC regulations now arriving open the door for IFR operations in Light Sport Aircraft. Dynon’s integrated navigation will provide a critical, space-saving solution for these airframes, allowing manufacturers and builders to deliver full-functionality IFR aircraft without traditional panel-stack penalties.
  • Seamless Autopilot Integration: Fully couples to the Dynon autopilot for rock-solid, hands-off approach flying.
  • Future-Proof Protection: Allows pilots to purchase and install a SkyView HDX system today and add full IFR capability as soon as certification is finalized.
Pricing and Availability
Dynon is committed to maintaining its legacy of affordability and will offer this groundbreaking capability at a highly disruptive total cost of ownership that represents a fraction of the cost of traditional, standalone panel-mounted IFR navigators. Advanced flight testing and certification efforts are well underway. Pricing and availability information will follow as release timelines are finalized.
Additional Information / FAQ
More information, including a list of frequently asked questions, are also available here.
An exciting development!
Does this mean that this functionality can only be used in EAB aircraft that meet the light sport criteria? Or is it able to be used legally on all EAB aircraft?
Also from the release:
Wondering if Dynon is working with Vans to lift the RV-12 Limitation that prohibits flight into both IFR and Instrument Meteorological Conditions (IMC)? Having a legal GPS driven navigator is one thing but maybe Vans has other reasons to restrict flight into IMC?
Saw that. Just a bit confusing, as they don't discuss getting the TSO's for the navigator function, so wondered if this was getting slipped into the newer ASTM stuff or has a new TSO. Always thought traditional Op Lims required TSO'ed navigators for IFR, though understand things may now be different if your EAB meets the LS criteria. Just trying to get some detail. Releases like this can be fuzzy about what is really coming.
So I guess I don’t need the ARINC 429? Also what am I gonna do with my extra panel space now! Been saving a slot for a garmin navigator, but I guess not necessary anymore.
For the GPS correct. They do not mention anything about NAV. If it is not incorporated then you may need it if you're going to use a NAV source. I was REALLY hoping for a GPS/NAV/COM to replace the 650 I have been sitting on for a year waiting for word from Dynon. I know GPS is almost everywhere but I do like the idea of a backup in VOR/ILS.
From Dynon
Q: How will it be certified? Will it be TSO’d?
A: We are currently engaged in the formal certification process with the FAA to ensure full compliance for both experimental and type-certificated aircraft. We are keeping the specific regulatory and technical details confidential while this program is in progress. Upon successful completion of our product and certification programs, this will be a fully approved, legal solution.
Does this allow for IFR flight with by the fact you can now load and activate via the MFD vs the stand-alone GPS? So we would no longer need something like a Garmin 650/720 just a GPS to the MFD?
Trying to understand what this means
From Dynon
thanks. very helpfull. Great to see another company break up the quasi-monopoly in this space!!!
This limitation was based on the light sport consensus standard rules. The same limitation applied to all special light support Aircraft.
The opportunity for IFR in special light sport Aircraft will be the result of the new mosaic rules.
This effectively will take the place of the Garmin 625 / 175 stand alone GPS units and replace with a remote box mounted behind the panel and accesses through the Skyview HDX efis. This is for GPS only. The 650 is GPS/NAV/COM.
with the new Dynon remote audio panel support and dual radio support inherent in the HDX and now the remote IFR box, a full dual radio IFR panel is going to be very space efficient.
Argh!
I just had my panel cut by AFS for an HDX setup and it includes a 430 I picked up.
Down the road I’ll have an odd blanking plate where the 430 is. And I could have moved a few things around when I was doing one of my last config meetings they told me about the remote radio before it was announced but not this.
I’m guessing it will still be awhile before it’s ready for release.
But exciting to hear!
This is probably due to FAA requiring a certified GPS navigator for IFR/RNAV, regardless of the aircraft category.
I would love it if it came to the AFS 6600 as well, but given that they don't have a certified PFD to start with, will that be a no go? Or is the GPS/Nav box the only piece that has to be certified, then as long as the AFS can control it, it's kosher?
Exactly.
I am very curious to see how this works out.
You may know that GRT has offered something that sounds similar (LPV approaches) for some years now. But, as a small company, they could not afford the cost of obtaining the TSO, and, without that, the faa would not approve ifr operations, so very few have been sold. So I’m wondering: is Dynon going full bore on the TSO route (estimated to cost millions of dollars)? Or are they hoping to get an alternate means of approval? And, surely, Garmin will react with a significant price reduction. Since they have long ago amortized the TSO cost, they can still make a small profit while undercutting Dynon’s price. To me, this sounds like a bold, ‘bet the farm’ move by Dynon.
Do you think a G3X is TSO’d? So far the faa’s interpretation has been just the gps receiver needs the TSO.
