E-Props has supplied two different digital protractors over the years. Since I have two complete propellers, I decided to compare the gauges.
The smaller protractor is rechargeable and measures in 0.05° increments at our typical pitch settings. When I checked both gauges on the same propeller, I found they differed by about 0.75°, with the smaller gauge consistently reading lower.
I bring this up because it's easy to focus on matching a specific pitch number instead of matching performance. E-Props blades are very consistent, so blade shape isn't the variable. If your digital protractor reads a little differently than someone else's, you'll still end up with a similar pitch, but the number on the display may not be directly comparable.
The takeaway is that the digital protractor gets you very close, but a flight test is still the best way to dial in the final pitch for your airplane.
