This is at best false attribution fallacy and at worst an outright lie (the only difference is motive). Read about the forced landing here:
http://sdsefi.com/rv12.htm
It was not an ignition issue, it was a a failed alternator that went unnoticed for 10-15 minutes combined with the assumption that there was enough battery to power the airplane for extended periods.
This doesn’t apply to the SDS CPI2 product because it maintains a dedicated battery, not one shared with the rest of the airplane, and because that battery only runs the fairly low powered ignition and not high current fuel pumps and avionics, it has enough power to fly the airplane for hours depending on size. Not only that but the head until will immediately show the alternator fault with a bright LED and audio warning if you wire it into the intercom.
You also point out the belt failing, but eveybody armors those wires and I’m unaware of a single forced landing due to that mode of failure. Besides, this is another fallacy, you can’t argue that checking mag shaft play is trivial and also people will forget to inspect the alternator belt.
You raise a reasonable point that electric ignition won’t survive poor install, but neither will anything else. You need to torque your nuts and use lock washers every bit as much as you need to use quality crimp tools and connectors, except that quality wiring with proper supports and connections almost never wears out.
When I first started building I told some old timers I was going to use a glass panel. They stared in amazement and asked how I could dare trust electrons, I stared back and asked how they can trust vacuum pumps.
Anyway, the fact of the matter is that electronic ignition isn’t more complex than a mag, it’s just different complex. You are trading electronics for harmonics and wires for metallurgy. I’m good with that trade, modern electronics are very reliable. I’m not good with the pmag because you aren’t trading mechanical complexity for electrical complexity, rather you are adding the electrical complexity to the mechanical complexity and worse, that electrical complexity gets to live in an environment that is constantly trying to kill it.
I stopped reading.
"This is at best false attribution fallacy and at worst an outright lie (the only difference is motive)" Calling me a liar, go away. Booo.
What the P-Mag does not have are sensors, wires, boxes shot gunned all over plane. Not there is anything wrong with wires, sensors, boxes, connectors shot gunned all over the hot vibrating engine compartment?
What could go wrong with wires and connectors running all over and hot vibrating engine, in engine bay with other things to chaff against and going through bulkheads? (Vibration, chaffing, wear, bad connection). Don't hate the messengers. I RECOMMEND you inspect your wires well just like P-Mag operators have to check their bearings.
You are being pedantic and petulant. Your remedial explanation of how things work was making what point? I understand the risk and design trade offs as I spent a career designing and certifying aircraft and aircraft systems, and then flying them. I have been honest, factual, correcting misunderstanding of the P-Mag. This has upset people who were secure in how much better their choice was. Do as you like is what I have said. I have said ALL EI's have Pros and Cons. When I point out Con's of other EI's it is total cognitive dissonance. WHAT?
Your EI can fail in many ways extra battery or not. Sorry. I have flown some aircraft with the most redundant systems in aviation. In GA aviation. SEL we have one engine. We have no redundancy of thrust. I digress.
You misunderstood what I said about Magnetos. It went over your head. I am NOT saying Magnetos are better than EI. What I am saying, magnetos are not the weak sauce people falsely think or are unreliable. They have a hot spark at high RPM. They also have fixed 25 BTDC timing (typically) which is a great compromise for full power, OK for 75%. EI is better, stronger spark across the full RPM range, timing advance at lower power. EI is "simple" in the aspects of no moving parts. So they should be more reliable. You seem to think I am saying Magnetos are better? No but spending $5000 to get an EI when you have two good Mags might not be the value added preposition you think.
On the other hand a 500 hr Bendix inspection replacing cam breaker points, capacitor, oil seal, slinger, and all felt washers/strips. It is about $500 with labor. The parts are about $100-$120, DYI is peanuts. If other items need replacement, impulse couple, cost go up. Overhaul of Mag is with engine overhaul (1500-2000hrs) and cost $1000-$1500 (again full overhaul exchange $2000). Not really horrible, so EI is not a MUST have for many. You can do a lot of 500 hr inspections at $100 in parts, verses a $5000 EI. For me I am 100% for EI because I was starting from scratch and got a good deal. I have less than $2500 into my two P-Mags (bought two 2nd hand, sent to Brad and company, inspected and upgraded, bought new harness and plugs at nominal charge). Was very happy with the service. Fingers crossed Hartzell will continue? The one story I heard was promising. Turn around time a little longer, cost a little higher but not unreasonable.
Empirically from my experience and experience of others with P-Mag over a decade, pretty solid. Perfect no, neither is your EI brand. Sorry
Since most EI's are in experimental aircraft, service difficulty data is incomplete. The bearing wear check of P-Mag is a nothing-burger, and did I say, I love
the EASE OF INSTALATION, TIMING AND SELF POWERED. So there.
Base Leg Aviation with their new IO-540 6 Cyl, RV-10, one electronic ignition a SureFly which is an accessory case driven EI like the P-Mag, one standard magneto. The SureFly of course requires backup battery.
I don't want to get into all the 6-Cyl comments, but it just sounds like irrational fear. Again don't care, do what you all like. Not bashing your choices.
"eveybody armors those wires" and "I’m unaware of a single forced landing due to that mode of failure." These are two "fallacies". You say EVERYONE? OK sure brother. Not true everyone, I can assure you, I'm an EAA Tech Counselor. A belt could move the sensor gap or just rip wires off. I say COULD so don't get mad. Sorry. Plus all the wires and connectors on a hot vibrating engine.... Than you say you are UNAWARE? That is a fallacy or a lie?
Ha ha. Come on man. I am "not aware", is not a winning argument or proof. I have examples of DA62 $1.5M diesel twin (electrically dependent engines) forced landing due to electrical issues.
It could happen. That is all I am saying. All EI have failure modes. P-Mag has a lot of Pros, one being indpendant of the ships electrical power.
If your dual EI uses the same set up, sensors are near each other, same power source, common control box circuit boards, well not as independent as you think. That is another case for keeping ONE MECHANICAL MAG. I know the EI makers try to make dual EI systems independent and redundant. But are they really? Of the sensors are close to each other not so much. They all share ships power or back up battery power. Magnetos and P-Mag are independent of electrical system.
But from a reliability standpoint MECHANICAL systems, Mechanical pumps, mechanical FI or Carbs, Magnetos (ono most of the GA fleet (for last 90 yrs) have worked and been very reliable, brute force, not subject the planes electrical system working. I agree electrical systems can be made very redundant, but looking at Bob Knuckles dual battery dual alternator and a Sea of switches. I have to laugh. Too complicated. You need a type rating. All this to assure electrical power for your EI? Glass? Yep that is the reality I suppose, but I want to simplify, not make it more complex, costly and heavy.
I admit the 5 switch throws to test the P-MAG on run up is a lot I guess, BUT, regular Mag has 6 clicks of ignition switch to check L&R Mags, 2 clicks off, 2 clicks back on, 1 click off, 1 click back on.
The RV-12iS as most know has EFI and EI. No mixture control. Lane A Off, On, Land B Off, On, Left fuel pump Off, On, Right fuel pump Off, On, that is 8 throws of switches in a LSA? HA HA. Good grief. Today in the RV-12iS, Lane (A) fault light came on during the flight today with another student (I think connection needs cleaning). No big deal. However two ECU's, EFI and EI, Gen A, Gen B, all the complications, wires, connections, ECU's, to be unburdened by the mixture control? OK. It is more efficient than the 912UL.
Another student, this one a primary student, in a C-152 currently, run-up, Mag check and carb heat, load meter/low volt idiot light off, done. No EFIS button pushing to get to fuel or electrical pages.
P-Mag is like the standard Magneto in this respect, independent from electrical system. THAT IS A BIG DEAL.
Good look in your flying pursuits.
