Crotch straps
bob888
I would like some opinions about crotch straps. I see 5 point belts from Crow and others but no apparent anchor for crotch strap in front. How about back seats, which do have anchor points for the crotch straps? My inclination is to go with 4 point restraints all around as this is not an aerobatic machine.
That's what I did. I cut off the rear anchor points. The danger in doing so is "submarining " during a sudden stop (accident) which I suspect will only happen if the lap belt isn't restraining the passenger properly or the passenger is too small.
D
I don't know the geometry of the -10 seats and belts, but I continue to regret not installing the crotch straps when I built my -6. Without the straps, the lap belt rides up if I properly tension the shoulder belts and I don't like the geometry of that. Also, when it is turbulent, a crotch strap would help prevent my head from bouncing off of the canopy top as frequently.
When I purchased it had 5-point on my side and 4-point for the passenger.
I'm replacing the interior and going with 5-point Hooker harnesses on both sides (they look awesome too!)
Pics will follow...
The RV-10 front seats have no provision for a crotch strap. As for the rear, I simply opted not to install the lugs and went with 4-point harnesses. I also went with Van's stock straps vs Hooker or Crow, they work just fine and match my interior perfectly.
I am not flying yet, but have spent some time in a friend's -10 and would agree with Kyle's assessment. The geometry of the lap belt seems to pull the belt back more than down and if the shoulder straps are pulled tight the lap belt tends to ride up to a less desirable (and maybe somewhat dangerous) across the gut position. Wish there was a good solution to a front seat lap belt!
Safety harness
As a racer, let me provide another prospective.
Most racing sanctioning organizations demand a harness with a sub belt. Some sub belts have multiple attach points on the car. There is a potential for the lower body to go forward under the lap belt especially if the lap belt rides high. The lap belt keeps the lower body from going forward/up, and shoulder harnesses keeps the upper body from going forward. The sub belts help keep everything in proper position. If you don't have a sub belt, tighten the lap belt firmly and then tighten the shoulder harness just snug. Don't tighten a shoulder harness to the point where it pulls the lap belt up. The lap belt needs to ride at the pelvic bone to prevent injury at impact.
We used to drive cars on the street without seat belts. Would you do that now?
Bottom line is that harnesses prevent injury. Don't deny that bad things happen. The better your harness system is, the safer you are.
Jim
Well at the end of the day it's all about risk acceptance. For me I assume the risk of submarining without batting an eye and spend my energy trying to reduce the likelihood of ever having to rely on the seatbelts in the first place. YMMV....
And yet another example of a decision that really can't, and shouldn't, be made via internet consensus. It is your life, and your airplane. Everyone needs to weigh for themselves the costs and benefits of their choices. FWIW, I understand that geometry of the rear seat makes the sub belt more useful/important than in the front. Personally, I make sure my rear seat passengers use the rear sub belt, and I wish I had one in the front too. But that is just me....
Sub belt
So the question remains, has anyone successfully figured a way to put one in the front seats of a -10?
Yes. I would like this answer too. I have kept the crotch strap lugs in my rear seats because I would like 5 point harnesses back there. As the previous posts demonstrate, you must know a little more about what you're doing to make a 4-point work well. If coming in for an off airport landing, what is the likelyhood of a rear seat passnger doing this correctly. That being said, even if the front seat occupants are "more capable" I'd love to have 5-point harnesses in the front seats also. If anyone has engineered a way to do this, I'd be interested to know about it. If not, I suppose I'll continue with 4s in the front and 5s in the back.
C'mon Guys!
Someone out there has had to add (successfully) a sub belt to the front seats of the -10...speak up, inquiring minds would like to know...
front seat crotch straps
I have a configuration that may be of interest. I'm traveling, but will be home in a few days and will post pictures and details..
Did It...
We did install submarine belts in the front seat of our 10. I have had the occasion to actually use belts in race cars and owe my life to seat belts from a car accident. As someone mentioned the most important thing is to keep the lap belt on the pelvis. I made a "Y" with a piece of cable and ran it to the seat frame of the seat itself, so it moves with the seat. Then I attached the belt to the loop in the "Y" cable. No pictures handy, sorry... But is has been done, and I am very happy with the results. - Jason
Crotch strap attachment idea
library
I used a bolt through the panel, under the seat. It is high enough to accept the removable Crow attachment, but does not interfere with the seat bottom. I'm sure it is not strong enough to meet all the G load requirements for certified aircraft, but I figured the load is in shear and should be much better than not having a crotch strap. The strap wraps around the front of the seat and must be pulled tight to avoid interference with the control stick. If it doesn't work as well as hoped, I can always remove it. I see no other way to install this?? I'd appreciate comments and suggestions. (Not sure about the attached pictures?? I'll see if they made it??)
Bill,
This is what I looked to do as well. Unfortunate I had the seats done already before I figured out that for this to work the front seats need a crotch strap slot like the rear seats.
Hooker sent me the crotch strap so perhaps one day I'll send the front seats back to DJ at Cleaveland tool and have her put in the slots.
Carl,
My plan is to wrap the crotch strap around the front of the seat rather than have it come through the seat cushion. I'm thinking this will avoid modifying the seat. The only issue might be the angle of the strap, at the seat belt release?? Also, I need to be careful to make sure the strap is tight enough to stay away from the stick.
Bill
Bill,
The stick is not really an issue.
I tried to just wrap it around the front of the seat - way too far forward to do much good.
The real question is to just go through the seat cushion or go through the seat bottom as well. I'm thinking the later will be what I end up with.
Dj did the mod to my rear seat cushions to add the crotch strap belt - they look like they were always made that way so I'm confident she can add the slot to the front seats.
How much room is there..
.. between the bottom of the seat panel and the stick mechanizms underneath? It would seem to me that two aluminum angles sandwiched around a seatbelt attach lug, riveted underneath the seat pan would work well.
You'd have to have a slot in the seat pan and also a slot in the seat, but it seems like the lug would be pretty strong this way, especially if you further strengthened the seat pan too. I'm just sure if there's enough room under there to do all that and still allow the seat to slide freely, without hitting any of the stick mechanisms.
One of my concerns was not modifying the seat structure. This is designed to provide adequate structure in a crash and did not want to change anything there. Perhaps Carl's thoughts about modifying the cushion and support webbing might be a good idea?? I'll have to see how it all goes together and consider possible cushion modifications at that time.
Bill
A friend and RV-9A builder once told me the bottom strap is still useful on a non-aerobatic plane, because it can potentially keep you from sliding out from underneath the waist and shoulder straps in a serious accident.
I was chatting with Matt from Crow at AirVenture, and he asked how the new 5-points we got for the RV-6 were working out. I said I hadn’t installed the crotch strap yet because I had some engineering to do - and he responded that the 6-point actually has the crotch strap anchored to the same points as the seat belts, but routes under the cushions (thighs). He said it’s a race-car thing, and he’s sending me a pair to try.
Will report back!
If you talk with the pilot of the RV-9A that went down in South Carolina - he will tell you the crotch straps probably saved his and his passenger’s life. Look at the pictures of the wreckage and you may get a sense of how lucky they are to be alive.
I can't offer this community much (anything!) from a build or maintenance perspective (1yr NBO), but I DO have 27 years experience in restraint systems and occupant safety. AmSafe Inc. did (and may still) supply the standard belts for some of the kits. This is why my -10 (and a few other -10s out there:cool:) have 4-point rotary buckle restraints with compact inertia reels which meet TSO-C114....wonder where those came from...;)
In my other life - from a loads perspective, when we performed dynamic testing on our in-house deceleration test sled for Part 23.562 26g seat testing, the loads were nominal, less than 500lbs in nearly every case. Keep in mind that this is with a very strict test regimen where the lap belt portion is tightened down where it's designed to be, across the hip bones. When properly worn, a high percentage of the total load is transmitted into the lapbelt attach points. The load into the shoulder strap depends on restraint geometry, but for Part 23.562 occupant safety certification, loads must be less than 1750lbs for a single strap and 2000lbs total for double shoulder straps.
Pilots get into trouble when they fail to make sure the lapbelt is LOW AND TIGHT first, then tighten the other straps. When the lapbelt is loose, the body slides forward and under the lapbelt - called "submarining". When the belts are loose, the body starts to move forward and accelerate, and when it does hit something, the results are ugly becuase the load pulse is short and peaks with very high G's. A properly tightened belt causes the crash loads to transfer to the seat/aircraft earlier in sequence, spreading the total crash energy across a longer time period, which lowers the loads seen by the human occupant. And no, people may think they're strong, but no-one can stop your body and limbs from impacting the panel and interior - even in a minor crash. When properly adjusted, the crotch strap serves to maintain the low alignment of the lapbelt so that it handles most of the crash loads. The crotch strap itself takes a very small percentage of the load, assuming the lapbelt is adjusted properly. In every case, the purpose of the restraint system is to keep the occupant in the seat and off the interior and concious. Many have survived the initial crash sequence only to perish in the post-crash fire becuase they were incapacitated and could not self-extricate from the aicraft. Apologies for the long post, but there's a lot going on in crash dynamics & occupant safety.:)
I am a very close friend of the person that owned thed referenced 9A. I found it for him over a decade ago, ferries it to SC, and flew with him a lot.
He thanked me for helping him with a lot of things in that plane, with the most recent being the crotch straps.
Loo at the included picture. The engine is snapped away about 45⁰ to the left. The instrument panel is folded UNDER the fuselage. The crotch straps that we put in was one of about a dozen miracles that saved them.
He is a doctor and was a race car driver in his spare time so he insisted on getting the best harnesses that he could find.
He is alive and well and preparing for some special checkrides with the FAA after all the surgeries on his leg and the rehab. He "only" had some broken bones on one leg and I think the passenger had minor injuries on one ankle. All this after their feet being on the ground after the crash (like Fred Flintstone).
I can speak in more detail about this OFFLINE as I was able to be there to photograph the scene and help find items (with the FAA). I have permission from my friend to discuss this with discretion.
By the way, all the FACEBOOK quarterbacks were WRONG. He is not a wreckless pilot. He practiced a lot and flew the plane well. It was "one of those things that could happen to each of us". And in their case, they survived. I say, due to 12 miracles in a row.
Did I mention that the right wing of the 9A was left up in the top of a tall pine tree?
View attachment 93838View attachment 93838
Forgot to mention.....
I promised him, while he was in the hospital that I would immediately go add crotch straps to my RV6. And I did.
Safety harness
Jim
Agree with Jim,
Personal experience with an 11.2g crash.
They helped save me.
Daddyman58
I wish I'd had more than just a lap belt in the Commanche 260 in 1992. God was with us that day we put her into some clear-cut in west Central Alabama.
Only injury was a spained wrist by right front passenger who braced for impact by reaching for glare shield.
Will report back!
Looking forward to hearing how this works out.
A four point seat belt system is fine most of the time. But the lack of crotch strap is a liability in moderate or greater turbulent conditions where the airplane is suddenly pitched downward. Your head is likely to hit the canopy above, and it can hit hard without the crotch strap. The other four points hold you laterally and from front to back, but unless these straps are tight, your head remains vulnerable. Get and use the crotch strap. Jim M
I went from original Vans supplied harnesses in my RV6 to Crow 5 points with the crotch strap. The difference the crotch strap makes is fantastic, even just for normal flying it allows you to strap yourself in tightly which I find makes it much more comfortable to fly aerobatics and whilst in turbulence. If the plane is bouncing around for any reason, I much prefer to be firmly attached to it rather than doing my own thing around the cockpit. The benefit in terms of crashworthiness should be beyond obvious.
20 years ago I sold Shroth harnesses for GA aircraft. In the process did a lot of studying about aircraft crash dynamics and 4 point vs 5 or 6 point. How the harness transfers loads into the body is significantly different without a 5th or 6 point harness. Consider that the body is quite fluid. In forward loads, the body slips under the lap belt of a 4 point harness with the lap belt ending
up damaging organs and breaking the lower ribs, often puncturing the lungs. With a 5th point, the crotch straps primary function is to hold the lap belt on the hips while allowing the shoulder straps to be tensioned without pulling the lap belts up. With the lap belts held on the pelvis, it eliminates the submarining of the body under the lap belt and the related injuries.
6 point harnesses can provide dual points for a crotch straps attachment OR, loop back under the legs to the lap belt attachment points. This ends up something like parachute leg straps.
Unfortunately, the RV-6/7/9 don’t offer a good shoulder strap angle, which can result in some spinal compression from downward forces as the shoulder straps take forward loads. AC43.13-2B chapter 9 has a chapter on shoulder belt attachment geometry.
I learnt a good lesson 2 years ago when I loosened my seat belts to reach for something and didn't tighten them up, and subsequently hit some turbulence. I smacked my head so hard I really thought I had broken the canopy. Then, sadly, I lost a friend this year flying a Sling TSI from CA to Las Vegas. He hit his head in turbulence , landed, told he told his wife what happened, and died a week later in the hospital from head injuries. I used my crotch strap so not sure the crotch strap limits vertical movement when you loosen the shoulder straps. But I use all the straps and now keep them tight.
Robert
so, did we figure out how to attach the crotch strap to something on the anchor end? Sorry if i missed that part of the discussion
If anyone knows of a working solution to this requirement, please post details!
Crow’s “six point” system is an easy answer and in my experince so far, works pretty well to keep the harness system positioned on your body. It uses the existing attach points for the lap belt to attach the “crotch strap”, so no mods to the airplane. Worth checking out.
I have been flying various RVs for years and each was equipped with 5 point harnesses in front. Initially I did not use the crotch strap. But after two successive episodes of sudden severe turbulence that pushed my head up into the canopy very painfully, I now use it every time I fly. Crotch straps have limited utility for aerobatics. Unless you are hanging upside down for several seconds, centrifugal force keeps you tightly in your seat. The crotch strap does nothing. Its main utility is to hold you in your seat in the presence of turbulence so your head is protected from trauma. Use it!
H
H
You are incorrect about the primary utility of the crotch strap. It is there to prevent you from sliding under the lap belt in the event of a crash an high deceleration rates. It keeps the lap belt secure over your pelvic bones.
While it may have a secondary utility in preventing you from banging your head on the canopy, that isn’t what it was designed for.
Crow’s “six point” system is an easy answer and in my experience so far, works pretty well to keep the harness system positioned on your body. It uses the existing attach points for the lap belt to attach the “crotch strap”, so no mods to the airplane. Worth checking out.
I'd like to see some pics of the Crow six point harness installed in an RV-10 and hear feedback from those who are flying with them in an RV-10.
TIA.
The real issue is utility independent of design. Preventing sliding forward in a crash is important too, but you will only, hopefully, have to sustain one crash in a lifetime. But turbulence is potentially present on every flight. Use the crotch strap! H
Don't have crotch straps in the -10; a properly secured lap belt will still hold you hold in turbulence.
I try and stay away from turbulence, though...
Obviously there is resistance to the crotch strap. I resisted it too. You may try to stay away from turbulence, but since it is invisible and only felt, good luck with that. The two recent instances of turbulence that sent my head into the canopy were totally unexpected. If you fly long enough, sooner or later you will experience this phenomenon. If your mind is already made up not to use the crotch strap, nothing I or anyone else says will change your mind. Do what you want.
It isn’t resistance to having a crotch strap.
Nobody doubts their effectiveness.
This thread is specifically about installing a crotch strap in the front seats of an RV10. Which is significantly different to the rest of the fleet. Hence most RV10s don’t have them in the front seats.
Break…
Here’s some photos I dug up many years ago when thinking about it. I don’t know whose they are.
Obviously I am ignorant of the question you are asking. The RV-10 is just as subject to turbulence as any other airplane. The crotch strap in my RV-7A and RV-14A was just under the bottom cushion in a slot receptacle in the floorboard. The same can be done for the front seat of an RV-10 and lots of builders do it. If the issue is whether it is a good idea to have a crotch strap for the back seat, common sense would say yes since the same turbulence that may push your head into the ceiling in front will do the same in the back. As for whether a lap belt will prevent head banging, it depends. I flew for years with only the lap and shoulder belts in place. My head still hit the ceiling. The only way to prevent it is either not to fly or to keep the lap belt very tight all the time. Better to keep the crotch strap tighter than usual and be comfortable in your seat. All of this seems very elementary. PS: nice pictures but they do not say anything out of context with the rest of the seat. H
Obviously, you must not know that the -10 does NOT have crotch straps for the front seats. It would need to be a modification, and the seat is NOT the same as your -7 or -14.
You misunderstand my comment. You stated the reason for the crotch strap was to prevent you from banging your head in turbulence; that is NOT what it was designed for, though it is a side benefit.
As far as flying long enough, I’m fairly certain that 30,000+ hours is long enough to know.
Well if it’s so elementary and lots of 10 builders do it, then feel free to share the specific details that would help add to the thread rather than take it into the weeds.
Many builders already have crotch straps in the rear. The airframe has the mounts as designed already.
So, again what is the question?
