Dismal failure? I am sorry you do not have data to support that. I have been a P-mag pilot for +10 yrs. I have talked to BRAD dozens of times and he is no bull.
The original bearing worked fine and upgrading Bearing was optional, and depended on engine & prop (vibration, HP, torque pulse, prop bal etc) which telegraphs those loads and vibrations into accessory drive and things hanging off the accessor case.
Time 500-1500 hrs was common before you saw play (play not catastrophic failure) was typical. 1000 hrs is typically 10 years for most pilots, so keep calm. This is ALL preventative.
To remind you all standard Magnetos have to be inspected and/or rebuilt every 500 hrs. Bendix Mag $1000-$1500 per Magneto, $1500-$2000 exchange. Keep perspective, STUFF wears out.
Newer bearing design under Brad (released a long while back), pre Hartzell, increased the diameter of bearing. It would be simple logic and design to last as long or longer. I talked to Brad. It was incremental change.
BTW the inspection takes less than 30 seconds to inspect the P-mag, but you do have to unplug it and remove hold down and pop it out. No play put it back in. NO BIG DEAL. Move on. People who never have owned, flew and maintained P-Mags make a big deal. Some owners do complain... and some don't bother with inspections. It is preventative. EI commander that reads the data port off the mag (an aftermarket product) can determine ignition jitter indicating there is play. Brad said that is nice, but not needed. You can hook your laptop up and run a program (I got from brad) and read the same data.
BEARING Hartzell deisgn? I HAVE NO IDEA? However 500 hr warranty or inspection is a NOTHING BURGER...They always typically gone 500 hrs and plenty more.
BTW Brad replaced bearings for pennies with a total time from ship to receive under 2 weeks. Often they would upgrade things no charge. I suspect 1st Gen P-Mags have been upgraded, but they were good from the Get-Go... just made even better.
Light Speed,
ElectroAir and
P-Mag ..... ALL have EI hall effect triggers that are mounted to the magneto accessory case drive.
THEY ALL WEAR OUT THEIR BEARINGS and SEALS... Don't know about SUREFLY, but they claim 2400 hrs between overhauls, with mandatory total rebuild by manufacture.
THINGS WEAR OUT. These bearings are not really lubricated. They don't just fail. you only need to keep an eye on them.
To call it dismal failure is to hyperbolize. The P-MAG is a great product, easy to install and
STILL THE ONLY ONE ON THE MARKET THAT IS SELF POWERED WHICH PEOPLE SEEM TO FORGET. That is a WWW BIG DOT DEAL
There is a long list of EI ignitions that failed in flight, not self powered, reliance on ships power, that have caused total loss of power. Not P-Mags.
Diamond DA42*DA62 (+$1M diesel twin), has had more than one off field landing due to the EI and EFI going Kaput due to no electrons. Self powered IE independent of ships power is priceless, worth the cost of checking and replacing bearings every 5 or 10 yrs as preventive maintenance.
