RV-9A IO-320-D1A with CS prop, second flight after condition inspection. Normal run up and climb out, gauges normal, engine running fine, normal power. I pulled the power back to 25/2500 (cruise climb), noted that the engine sounded a bit quiet and airspeed was falling off. Engine sounded completely normal and responded to throttle.. As I turned back for the airport I did all the usual stuff for a partial power situation, no change. I landed normally taxied to the compass rose and repeated the run up (mag check, throttle response, propeller) all non-illuminating to me. I had my mechanic look it over carefully yesterday. Pmags were fine, timing normal, no wobble, no throttle or fuel issues, no evidence of induction leak. I flew it this morning, orbiting the airport. Starting and taxi were normal. Run up was normal, engine and throttle response on takeoff were normal. At 1000 ft I pulled the power back to get it to 25 inches (cruise climb). The engine changed pitch but the MP gauge (AFS 5400) showed it was stuck on 29 inches no matter where I set the throttle...even pulled back to idle on final approach. After shutdown, the MP pressure read 30 (altimeter was 29.93)
I am NOT an airplane mechanic. My mechanic doesn't think this is an induction leak (he checked at CI and re-checked yesterday). Is it reasonable for me to assume this is a sensor failure? I haven't looked at it but I'd guess this is a Kavlico sensor P4055-30A-E4A or similar and my inclination is to just replace it after confirming. Any other things I should be considering?
taxiing back to the hangar..
