Hi guys, my RV-12 has its airworthiness cert but hasn’t yet flown off the first 40 hours. If I sell shortly ,what should the new owner do to satisfy the FAA? Re-register the airplane….what to do?
Thanks, Pierre
Thanks, Pierre
Add : get a ferry permit to the new area also if you can to avoid the highwayThe new owner has 2 options. (1) Continue Phase I testing in the original area, or (2) Have the Op Lims amended to the new owners home area.
I'm curious Vern if a ferry permit can be issued for this? I was told by a local FSDO field agent that ferry permits can't be issued to an EXP, and a log entry that the aircraft was safe for flight was all that was needed (if in phase 2)....however that would not suffice getting one to a different, amended phase 1 area. In my case, helping a friend by a phase 1 aircraft, we were able to make the existing P1 area, and the new P1 area overlap and move forward..but it took a DAR.Add : get a ferry permit to the new area also if you can to avoid the highway
Thanks, Mel…..The new owner has 2 options. (1) Continue Phase I testing in the original area, or (2) Have the Op Lims amended to the new owners home area.
I certified an RV-7 in the Savannah Ga area. The builder moved while in phase 1. The ATL FSDO issued a ferry permit to the Atlanta area and I was contacted to issue amended Ops Lims for a new phase 1 Area.I'm curious Vern if a ferry permit can be issued for this? I was told by a local FSDO field agent that ferry permits can't be issued to an EXP, and a log entry that the aircraft was safe for flight was all that was needed (if in phase 2)....however that would not suffice getting one to a different, amended phase 1 area. In my case, helping a friend by a phase 1 aircraft, we were able to make the existing P1 area, and the new P1 area overlap and move forward..but it took a DAR.
was this register as ELSA or E-AB? only 5 hours for ELSAHi guys, my RV-12 has its airworthiness cert but hasn’t yet flown off the first 40 hours. If I sell shortly ,what should the new owner do to satisfy the FAA? Re-register the airplane….what to do?
Thanks, Pierre
Thanks ‘N’…..I’ll check.was this register as ELSA or E-AB? only 5 hours for ELSA
That was meI certified an RV-7 in the Savannah Ga area. The builder moved while in phase 1. The ATL FSDO issued a ferry permit to the Atlanta area and I was contacted to issue amended Ops Lims for a new phase 1 Area.
Vern
How did you find that out?It's EAB.
This seems odd.
The original post states that the "40 hrs" has not been flown off. There's a clue in itself.Your ad in the classifieds indicates you installed a UL Power engine. Ergo, it has to be EAB.
ELSA does not allow the builder to alter the design, to include installing unapproved engines, propellers, avionics, etc.
