Vetterman blue hose type
nohoflyer
I received one length of hose in my exhaust box that won’t be sufficiently long. Does anyone know the type of hose they use?
Keep in mind that the hose segments shouldn’t be long sections with no tube inside.
If you do that, everything will be very flexible and the hose will stretch and allow the system to sag.
The hose should only be used to couple together the support tubes with no more than about a half inch gap between the two ends of the tubes to allow just a little bit of flexibility.
If one of the pieces has part numbers, plug that into a browser and see what it finds.
I agree, but it may not be possible on the Elastomeric set up.
