I have the following in my rv 10 fuel system. Left and Right tank pickups go to the Andair Duplex fuel valve. From there to EFII fuel filter and EFII Auxiliary pump. From there to the firewall, then a line to the mechanical pump, the mechanical pump outlet T's to a Garmin pressure transducer on the firewall while the main line goes to the input for the Airflow FM 150 throttle body. From the throttle body, the metered fuel goes between cylinder 3, 5 and enter the red cube immediately before going into the fuel spider. Engine is factory new with 10 or so hours TT. Fuel Lines are fire sleeved and from TS flightlines.
When I am flying with the aux pump, I have 30+ PSI and everything runs fine. If I shut the aux pump off PSI quickly drops below 15 with no sign of stopping. I have repeated these results with both tanks.
I have already replaced the mechanical fuel pump with a new one and have the same symptoms. I made sure to have the pin Raised and was able to put the pump in by hand without forcing it. I also took the magneto off and was able to put a scope down and am pretty sure that I saw the pin resting on top of the Fuel pump lever.
Prior to starting the engine with the new fuel pump, I capped the line going into the throttle body and pressurized it with the aux pump. Although it showed a slight leakdown of tenths of PSI per minute, 12 hours later the line still had enough pressure to squirt everywhere when I took the cap off of the line, leading me to believe that there is no air suck anywhere between the Aux pump and the Throttle body.
I am struggling to come up with my next steps to troubleshoot. Is it possible that the pin that drives the fuel pump lever is not actually moving? It seemed to move fine when I replaced the pump, but I didn't try and rotate the engine to see how it moved. I am hoping the answer isn't taking the pump off again....
All thoughts are appreciated.
Eric
Eric
