This applies to all the "A" models with Elastomeric Gear. The destructions mention adding up to three pads as needed. I don't see the method to add them. I'm slow. What's the process?
Jack the tail down to lift the nose.
Remove the nut
Allow the gear to drop
Add the pads
Reverse the process
Is that right? Will the gear drop enough to slip the pads in place?
Remove the nut
Add the pads
Reverse the process
