IO-360-M1B
A friend spotted some oil during my Condition Inspection. I found the source. The oil temp sending unit. Its just forward of the oil filter. It has a soft copper gasket similar to the oil screen. It was installed135 degrees past finger tight.
I put a wrench on it and it wasn't tight, but that's probably the way those crush gaskets fit.
Questions
1. What is the part number for the gasket?
2. Is there a better option?
3. Is 135 past finger tight correct?
4. If not, what is correct?
Thanks in advance
Questions
Thanks in advance
