Enclosed trailer for transporting RV12iS
CWW
I'm New Here
I believe I've read every post on the site relating to this subject, but I'm not finding anyone who's been successful. I'm hoping to revive this conversation from years ago to see if anyone is successfully hauling their RV12 in an enclosed trailer. If so, we'd love any tips or tricks for building out the interior to load/unload and safely house the aircraft for travel.
We just picked up our trailer that was built with a custom 97" ramp door opening. We plan to build it out making any modifications needed along the way. We'd love to learn from others who may have already done this.
I believe that somewhere in the depths of the site you should find a very innovative trailer that 'checked all of the boxes'. It employed a ramp at the front wherein the nose wheel would travel up the ramp and thus lower the tail such that the rudder didn't require the trailer to be unreasonably high or have a custom fairing. The wings were hung from the sides and strapped to the walls to prevent movement. The fuselage sat in the middle. The wheels traveled in rails to ensure alignment. The plane was winched in using the attachment on the nose wheel.
When I transported my fuselage from home to the airport (only 1 trip), I made plywood wing spar stubs that engaged in the attach points but only extended a foot or so outside of the fuselage. I used those to secure the fuselage to the trailer deck.
See post #28 from:
I asked a similar question a while back, here's the thread.
Pictures below show how i crossed the country on the road. It works well but wish suspension on dual axle trailer was better.
Better in this case, probably means designed for the lighter load. Most dual axle trailers are tuned with stiffer springs for the heavy loads that a dual axle would more commonly carry. This is worth discussing with the trailer dealer/builder if buying something specifically for this purpose.
