Hi everyone
I recently bought a new to me RV3 out of state. I’ve been traveling back and forth to work on it periodically. It’s temporarily parked outside until I can get it back home.
The original builder did a good job with construction but when he built it riveted on (each) wingtip with approximately 80 (yes 80) pop rivets per wing. I want to open up wingtips for doing some work to the nav lights and general inspection. I don’t plan on keeping the plane long term (already have an RV4), but don’t want to botch things up either.
I’m thinking drill out the existing rivets and then countersink holes around 40 holes in each wingtip, use a backing strip, and then fill in old alternating holes and touch up. Does this seem like a good plan? (I’m not a builder yet but getting started soon). I was hoping to use soft pull rivets to install the nut plates if possible since it’s an outdoors modification with limited tools available.
Thoughts or ideas.
Thanks!
Rick
Thoughts or ideas.
Thanks!
Rick
