rhinoviper787
Anyone installed the Aero Garage Ti-Down? Ordered them and the threads get very tight 1/4” in.
Tiedown bracket wasn't tapped deeply enough....General question about tie downs rings:
Mine are from Vans and seem too long. They will not thread in all the way. I'm reluctant to force them but the bending moment will be higher if I can't screw them down. Is this normal?
I had to tap my tiedown mounting blocks a little deeper after they were already installed, not really a big deal if you're careful.
This is great info. Do you know the thread/tap size off the top of your head?Tiedown bracket wasn't tapped deeply enough....
