SUREFLY SIM4P Failure
eatonair
This may be covered in different thread but I couldn't find anything. Have an RV6 with IO-320 and installed Surefly Sim4p about three years ago thinking it would improve reliability (even though I've never had a magneto failure). Suddenly had left mag (Surefly) problems at 209 hours. Fortunately it occurred at my home airport and landed without issue.
Experienced slight engine roughness after takeoff with occasional misfire. Returned to airfield and by that time the mag check revealed a much worse left mag. Engine would barely run. Did all the required troubleshooting, cleaned plugs, leads, even cleaned fuel nozzles. Engine started once with p-Lead disconnected but very rough on left mag and now refuses to start at all.
Removed the SIM4p for repair but from what I hear, I'm expecting to be told that I'll have to purchase a new one now that the warranty is expired. Will ship it out tomorrow and wait to see what happens. My confidence in the Surefly has been shattered and I'm seriously considering putting the original Slick back in it's place. Very Disappointed to say the least.
Wondering if anyone has had similar experience and what has Surefly customer support provided? Any thoughts? Thanks in advance!
Please post the details about how they deal with this issue. We don't hear much about surefly issues here, at least not that I have seen. In fairness, no product has a 100% reliability rate. Anxious to hear how they treat repair. If the answer is "buy another one," that is a red flag.
This is a bit odd. If the surefly went offline, the engine should run just fine with no misfires. You may notice the slight change in engine sound of running on 4 plugs and small power loss, but no misfire. Possible the surefly lost TDC and fired early, creating the issues, but also worth some time to be sure your Rt mag is performing at 100%.
I thought so too. But engine runs fine on right Slick mag. Unfortunately no impulse coupling on right mag. Rely entirely on Surefly for starting.
I have since spoken to Matt at Surefly to arrange for bench check at $200 but he suggested that because of the low time, he might adjust that.
My model is a Revision B which they apparently no longer repair so I'll wait to see what the diagnosis is.
What ignition harness are you using? I had similar symptoms, but the problem was the harness, not the surefly. It really does need a good quality harness. I got by with a cheaper ACS harness for years, but upgrading to a new Champion harness fixed the issue.
I had a Surefly go tango uniform on my Bonanza. Wasn’t the harness because that was a new replacement when the mag was installed. Customer service was excellent. I checked what they asked me to do. They sent me a replacement and I returned the box with my mag in it. Easy peasy.
The SF mag will not work without power. I hate to ask the obvious but was it getting power or could it have been a loose or corroded connection?
Using the champion harness. The system has been great for years then overnight this. Will find out when Surefly does the diagnosis.
It was definitely getting power. Fuse was fine. Even still blinking the correct DIN code. Probably going to reinstall the Slick mag while I await the findings from Surefly.
What did the EGT's do on your engine monitor while the engine was misfiring? Were there indications of misfire on all cylinders or was it isolated to a single cylinder?
Skylor
Certainly good to hear they are willing to work on it and at a fair price.
Skylor
After takeoff it seemed like a very isolated misfire. Didn’t notice an immediate change in egt’s . I’m using the GRT EIS , so I had to switch over to the EGT page while troubleshooting and navigating. Decided to return to the airport as a precaution and I’m glad I did. By the time I got on the ground , the Surefly was barely firing at all. I hate to say it but I think the Slick mag saved my bacon.
Whatever ignition you had on the right side would have saved your bacon....that's why we have two ignitions.
I also have a SureFly on the left and a non-impulse Slick on the right. I'm definitely interested in how your saga is resolved but one failure report isn't going to tempt me to abandon the SureFly.
I like your optimism! Will definitely post the results.
Me too……….
From a redundancy point of view, and aiming for that 100% dispatch rate, you should consider adding an impulse coupling to the non-EI mag. Don't forget to rewire the ignition key-switch (remove the jumper) or change switch-ology/procedures to enable/allow for ignition on BOTH sides instead of just the Left.
Or if it's easier for somebody's particular installation, I suppose you could just replace the right (non-impulse) mag with an EI, and change the ignition switch wiring as above.
SureFly advocates for replacing the left (impulse) mag if you're only going to install one:
SureFly recommends replacing the impulse coupled magneto. This is to reduce the possibility of impulse coupler mechanical failure and also to help the engine start better.
...which I guess makes sense as long as you assume the SureFly can never fail!
I guess you have to decide which is more likely (as well as more destructive): a SureFly failure or an impulse coupling failure. Personally I'd rather have a SureFly failure than have an impulse coupler destroy itself and possibly my engine. And as others have stated, SureFly failures seem exceedingly rare.
Chris
I guess you have to decide which is more likely (as well as more destructive): a SureFly failure or an impulse coupling failure. Personally I'd rather have a SureFly failure than have an impulse coupler destroy itself and possibly my engine. And as other's have stated, SureFly failures seem exceedingly rare.
Chris
That is precisely why the impulse mag on my O-320 was replaced with the SureFly. The left mag was coming up on the service interval and that was all the incentive I needed to never again have to worry about a catastrophic impulse failure.
Just thinking about all the magneto failures I've experienced, the impulse coupling wasn't on the Pareto. Come to think of it, the 500 hour mandatory service on the mags applies to both types.
But, yes, generally speaking, in order to improve reliability one should reduce/eliminate/avoid mechanical complexity where ever possible.
Another reason could be that they figure the hotter spark may light excessively rich mixtures that a mag won't touch, thus better starting on flooded IO engines.
Who knows, but it does appear that mags are pretty dang reliable when subjected to so much heat and vibration.
I sure don't feel quite so optimistic about mags. Had one Slick well short of 500 hours fail in flight with an open secondary on the auto transformer/coil and had the two new ones on my new engine only make about 350 hours before needing to be overhauled, due to what apparently is recent poorer quality of parts (specifically the cam follower plastic sourced from China). That convinced me to go left side SureFly. My local airport maintenance facility is an authorized magneto repair/overhaul/re-build shop and they see failed mags all the time in addition to the 500 hour mandatory service.
I am considering just that. But if one mag is bad, I’m not going anyway. Another impulse coupling just adds to the risk. The ignition system is supposed to be simple and bulletproof.
I feel your pain. I actually have the tooling to do 500 hr service on the Slick mags. Know them much better than the Surefly. I don’t skimp when it comes to performing all bulletins on Slick/Champion products. Having said that, I feel somewhat vulnerable not knowing the Surefly product.
I had a mag to failure on my private pilot check ride when I was 17 years old in a C-150 I was under the hood doing instrument maneuvers. When I. Optics engine running rough. Thought it might have been carb ice. Turned on carb heat and it smoothed out. Dexamilsr kind of looked at me strange. Then asked me to do the next maneuver. Again it ran rough and this time I pulled carb heat and left it on. The body language of the examiner indicated he didn’t know what or why I was doing that. Then the engine hiccuped a little and I told the examiner the engine was not running right. He told me to take off the hood and fly back to the airport. On the way back he said let’s try to see what is wrong. He asked to go from both to right mag. And immediately the engine quit. I quickly turned back to both and engine ran. The examiner then stated “well at least we know what the problem is!” By downwind I had to switch to left mag only as it was too rough on both. Landed. Had the mag to replaced and finished my check ride the next day.
The examiner had no clue the engine was not running right and at 17 years old under the pressure of pilot exam and under the hood I identified an issue. I think the examiner felt ai probably would make a good safe pilot. And I passed my check ride!
One of those days in your life that you don’t forget!
That's fair... I just pulled mags off of my 170 after 600 hours.... they were fine.... But you have more data points than me.
My new build doesn't have mags, CPI-2. I wanted EI, just not EI with electronics bolted to a hot vibrating thing. Having a dedicated backup battery is no big deal.
cool story.... when I had my check ride my DME had skin cancer on his dome and had some skin moved from his back side to his top side.... he wouldn't wear a headset. Of course it was crazy busy on the first lovely day at Merrill so there were a LOT of airplanes. I'm talking to the tower, he is just riding along. I ask for a deviation and ship creek departure, no good, get to cross the drink at 700.
So I'm under the hood then he asks for a minimum speed turn, no problem, then he asks me to fly to the Big Lake VOR, but my VOR doesn't work... so I open the VOR page on my 495 and then take my headset off and yell, that one doesn't agree with that one, we're going to go with this one pointing to the 495. We fly to the VOR and when the page read zero miles I said we are over the VOR, then he said fly us out on the 180 radial... I've never heard those words before... VOR was broke... So I try to figure out where I'm at in my head flying the airplane under the hood, not wanting to cheat and use the map. Then I took my headset off again and said, "That's the dumbest crap ever, I'm going to fly towards the VOR pointing at the heading on the 495 then turn 180"
He says, let's head back, okay, so I have to talk to the tower, deal with the air force base, cross the drink, while yelling at him explaining what I'm doing because he can't hear the radio, then he asks me to do a touch n go, then another, then land.
I figured I failed, no S turns, no turns about a point, but he passed me. Talking to my instructor he figures that the guy saw me solve a navigational problem under the hood and fly the airplane well and that's all he needed...... or he didn't care....
That's Alaska for you.....
That's not necessarily a good idea in my opinion. Really, a dead ignition system on the ground should be considered a no-go item. The second ignition is there to allow you to complete a flight safely, but taking off with only one known good ignition is not such a great idea because you are left with no redundancy, and the most critical phase of flight is probably the takeoff. Secondly, the impulse coupling is the most unreliable part of the mag, so for reliability it's probably better to leave it off if the electronic ignition is used for startup.
Skylor
Skylor
You know what they say about opinions... ;)
The second ignition is there to provide a complete combustion event *and* redundancy to continue the flight to the destination.
The first usage model of an additional impulse coupler is to improve the starting sequence. As you know, the typical keyed ignition switch ( A-510 ) includes a jumper to ground (disable) the non-impulse (R) magneto so it doesn't fire at the normal 25° - 17° BTDC and break things (like starters, flywheel).
Respectfully, If you look at the Pareto of magneto failures, the impulse coupler is pretty far down the list. Typically it's the breaker points, capacitor/"condenser", coil insulation failure - flashover, and gears, and the P-lead wiring.
while that is true, only the impulse coupler failure can trash your accy case gear train when it fails. that can get very costly.
SureFly SIM4P update. Received a call from Matt at SureFly today. They received my SIM yesterday afternoon (Thursday) and promptly diagnosed the problem as a loose coil pack. Matt didn’t disclose any other issues but did confirm that the unit was not repairable as I was afraid of. Revision B is not repairable . I don’t know enough about the SureFly to understand how a coil pack comes loose ( would really like to disassemble one to see how it’s made).
Was prepared for the worst when Matt offered a repaired unit at no cost because mine only had 209 hrs ( even though the warranty on mine was clearly expired ). And even offered to ship it out today! I mean who does that?
I have to say that I feel much more comfortable with the SureFly knowing that the customer support is second to none and they are willing to stand behind the product.
I’m confident that the repaired ( And now repairable ) unit will last longer than 209 hrs. ! Wish me luck !
Ray
Ray
So good to hear they are taking care of customers. We have a pretty good idea how hartzel , pp or pmag, would have hadled it 🤲
Thanks for the update, Ray.
While it's disappointing to hear about the problem (because the last thing I want to see is a SB issued and find we have a reoccurring 500 hour inspection or something), it's good to know Surefly are standing behind their product. I've got just over 230 hours on one unit, just under 200 hours on another one and about 80 hours on a third unit, so I'm very interested in seeing how this plays out.
Yes, I was pleasantly surprised by the offer. Like you said, unfortunately this kind of support seems exceedingly rare in general aviation these days.
I got the impression that they were genuinely concerned about product reliability ( as any manufacturer should be ) and didn’t waste any time tearing my SIM apart. Matt seemed to suggest that my problem was very unusual, but wasn’t at liberty to share a great deal more.
I’m guessing/hoping that since 2022 ( Rev B ), perhaps some of these issues have been sorted out. Will keep you all updated.
Ray
Remember that the guys who own surefly have sold PP and Skytec to Hartzell/ signia whoever…. So they just want to keep up service long enough to make a payday
So just a quick update on the SureFly saga.
Received the Rebuilt SIM from SureFly last week. Looks like a new unit and Rev H with 8130-3 included. Matt assured me that they replace all internals, no electronics get reused. Installed the rebuilt unit Saturday, engine run and test flight were flawless. Returned to home field and tucked the RV in for the night.
Returned Sunday for a breakfast run and cheap fuel (well..cheaper). Departed FA44 without a hitch and landed at OBE feeling pretty good about my airplane again!
Went to crank up after fueling and was horrified to hear no engine noise. Cranked for what seemed like an eternity and nothing. Not even a pop. Thought maybe it was flooded but no. Tried everything, even deliberately flooding it! Now I'm frustrated and know that the new EarthX battery won't last much longer and is probably going to die. It did shut off briefly as it's supposed to do when taxed. Was getting ready to tie down the airplane as I had no tools, and arrange for alternate transportation. Decided to give it one last try and finally got it to sputter to life. I have never had this much trouble starting a hot engine. I won't be going anywhere with this mag again.
Crazy thing is, the mag check after starting was normal. Engine ran fine. (Battery wasn't happy)
Flight back home was uneventful. attempted another hot start at home with exact same results. Will have to troubleshoot per Surefly all over again. After which I'll put the Slick mag back on the left side. :(
Ray, RV6 N6LV
Ray, RV6 N6LV
Good to here they took care of the problem, but sad to hear you are still struggling. If it consistently starts well cold, there is a possibility the hot start problems are a coincidence. Let us know how the troubleshooting goes.
Electronics can suffer situations where they work fine at room temp, then fail when hot. Suggest next time you have this issue put an old school timing light on the plug wires and observe while cranking. If the light is flashing, the plug is firing. It could still be firing at the wrong time, but at least confirms it is firing. may help in diagnosis.
It's starting to smell like the SureFly unit itself might not be the problem. Has the power wire and fuse holder been replaced, just to rule out an intermittent power issue? P-lead switch and wire as well? Any involved system with a possible intermittent failure condition should be placed on the suspect list.
