Sorry for all the questions. Have read a little bit here and there across different threads.
Just wondering what most are doing with pressure testing of the tanks. Testing prior to riveting to rear spar or after?
Has anyone who has tested either standalone tank or after riveting found a leak?
Is there any reason to wait to close up access holes in tanks once the fuel senders are mounted?
Has there been a definitive answer on using the same fuel senders and mounting one upside down from Van's?
Does anyone have an estimate of how much tank sealant is required for access holes and fuel senders?
Getting close to running out of work. Want to move on to tanks but must decide when to order tank sealant. I have 6 year old sealant that has been in the freezer the entire time that I don't plan on using on the tanks.
