Totally confused, I routinely fuel my cars with ethanol-free 91 octane unleaded at a local station. Small cost difference but that's it.
Been looking into the possibility of a Rotax powered aircraft and seeing mention on the Web of paying for an STC to have "permission" to do the same with aircraft????
I'm hoping someone can explain why an STC piece of paper is required, what benefits or protection's does one provide or is this just another bureaucratic FAA paper chase? Sorry if I'm letting my slip show.
Thanks for any explanations.
For certified aircraft they have a type certificate TC. Every aircraft manufactured must conform to the TC, and continue to conform for its entire lifetime. The TC if you read one is a wealth of information. Airspeed markings ie white, yellow arc, redline that all came from the TC, required placards…you got it TC. (Yes I know ADs can require placards) Approved engine and prop configuration…yup TC. Anything that deviates from the TC makes the aircraft unairworthy. BTW a certified engine has its own TC.
What fuel you can use is on the TC.
The S in STC is for Supplemental. After much testing, proving, and gnashing of teeth the FAA grants the applicant of the aircraft modifications an STC. They now own the STC. BTW it ain’t a cheap process. The sale of STC is hardly a money making scheme, it’s generally a recoup of costs. There are some that are lucrative. It’s hardly a get rich quick scheme.
That STC allows what is essentially an approved addendum to the TC. It’s not a blanket addendum however. The STC owner can keep it all to themselves or they can share it with other aircraft. Usually means selling it to you for a specific aircraft.
You must be in possession of the STC and the installation must conform to the STC. If it doesn’t conform…you guessed it it’s not airworthy.
STC is about an approved modification and the aircraft’s airworthiness compliance.
It’s all about airworthiness.
To answer your question, no it’s not bureaucratic paperwork.
