G3X Auto Pilot Settings RV-12iS
jackking123
Was having auto trim issue, Getting the Trim UP or Down Message with autopilot engaged (auto trim enabled).
I updated the RV-12iS_AFCS_Option_Rev_3. The G3X firmware was also updated before.
The roll and pitch TORQUE is now at 100% for pitch and roll after I installed this CONFIG? Really>
I did not record gain settings post CONFIG file, not at airplane right now.
Settings BEFORE Config File
Pitch Torque 80% gain 1.4
Roll Torque 50% gain 0.7
Min Speed 55kts, Max Speed 125kts
Does anyone have some RV-12iS Autopilot and Trim Settings they like to suggest.
Thank you. I looked at my other thread under RV-12iS and did not see specifics. Did I miss it?
New question here is The REV 3 Autopilot CONFIG file I uploaded rolled torques up to 100%... Sound right to you?
Before I do a test flight I going roll it back to 80% / 50%.... Pitch/roll torque.
The torque is force to override the servo on percentage of servos max torque. You can set it to 100% but will make it harder to over ride. Common wisdom is set it to the lowest possible torque which allows auto pilot to move flight controls.
