This is a RV-12iS with a red switch between the seats at the aft end of the center console. The switch, three position Center OFF, Momentary and Latched, is on angled panel facing forward between pilot and passenger seats. You really can't look at it, do it by feel.
Pull switch Up - Flaps Go Down.
Push switch down - Flaps Go Up. Switch latches, does not require you to hold it up.*
* RV-12iS flap up latches, so the motor runs until you put switch in CENTER? No standard limit switch.
It seems backwards, Did the builder install this incorrectly? Looking at other pictures of RV-12iS this is how it is down.
