My RV-10 has a PPS, a VP-X and dual P-Mags. The P-Mags are not powered through the VP-X. They have dedicated circuit breakers. The feed for those CB's is piggy-backed to the Battery + lug on the PPS (lower left lug of PPS).
Wired as it is, unless the P-Mag breakers are pulled, the P-Mags remain powered when the master is Off. There is a note in the P-Mag manual which suggests wiring a dedicated 16 AWG lead to the battery (in the RV-10) to prevent power dips which could inhibit ignition operation while cranking. The way I have mine wired isn't exactly the same as what's suggested in the P-Mag manual but what is the same is that the P-Mags remain powered at all times, unless the breakers are pulled.
I'm contemplating simply moving the P-Mag CB power lead from the PPS' Battery + lug to the Main Bus Out lug (top right). Doing so would remove power from the P-Mags when the master switch is Off.
Does anyone see a problem with this? I just wonder if the voltage on the PPS Main Bus Out lug is the same as the voltage on the Battery + lug while the starter is engaged? If the voltage is lower on the Main Bus Out lug than the Battery + lug, then I suppose this could introduce the scenario described in the P-Mag note.
I haven't as of yet attempted to record voltage readings from the two lugs while the starter is engaged. I figured I'd ask here first. I would have emailed Chad at Astronics, but that ship has sailed.
