Fenderbean
I am building an RV10 and will need to do the battery mount and auto pilot servo mounts soon.
is there some new battery tech out there for better lighter batteries for airplanes? Not sure if it matters but I plan to run a generator type on the back of the motor with the primary alternator.
I also would like to add something to keep the battery in charged during hangar times so any help here is also appreciated
Lastly I would like to add an external power support so I dont get stuck in my travels.....Any recommendations here would be nice as well, I feel having a small door on the tail cone vs inside the baggage area is better to prevent ground support peeps at an airport that may unplug for you an easier less room for error solution. Much rather have a small charge door left open vs my baggage door.
THanks up front!!
THanks up front!!
