UMA 1-1/4 Engine Instruments Monitor your engines vitals with a full line of space saving 1-1/4 engine instruments with 240 degree analog sweep. These instruments allow you the opportunity to utilize panel space without compromising read
Just a comment…are you sure you want the 0-80 psi scale? They make others. When I glance at an analog gauge and see the needle sitting in the one third position my initial reaction is one of being uncomfortable. The needle should be sitting somewhere in the 2/3rds position during normal ops.
And btw…it has been my experience that UMA makes really good instruments and their customer service is exceptional.
I have this one - working when removed. A little dusty in the picture: cleans up fine. I’m not able to get a better picture at the moment until back at the hangar $100.
Note: this is a mechanical fuel pressure gauge from UMA. It has the custom green painted range from UMA, unlike the generic ones on spruce
It does not have a sender. It is a direct read for the fuel pressure.
Agree with Robert about UMA - awesome to work with. They completely rebuilt, custom repainted and turned around an air speed indicator for me in two or three weeks at about half the price of a new one on Spruce.
There was a point last year where you couldn’t find an air speed indicator in stock anywhere. Just buy a broken one by UMA — no matter how old they can turn it around and rebuild it as long as you get the case back and they do it quickly.
