B Blizzard Well Known Member Friend May 17, 2026 #1 The cable shielding to my GTP 59 is grounded at the GSU 25. Do I install the grounding loop attached the GTP 59 or leave it disconnected? If I install it, it’s going to be grounded at both ends and I’m pretty sure that’s not supposed to be done.
Walt Well Known Member Patron May 17, 2026 #2 Yes, the attached terminal end fits over the probe for a reason. This is not an audio system!
B Blizzard Well Known Member Friend May 17, 2026 #3 Walt said: Yes, the attached terminal end fits over the probe for a reason. This is not an audio system! Click to expand... Thanks Walt. I already had it on but just wanted to be sure.
