Basically done with construction, so I'm starting the PAP. The trim up/down buttons (both sides) don't do anything.
I disconnected the trim motor and tested the motor itself with a 9V battery. The actuator moved in and out as expected.
I have the Dynon avionics with autopilot.
There's comments in the PAP about the trim speed adjustment, but most of those comments seem to apply to the Garmin setup. I removed the tunnel side panel and adjusted the speed control to both extremes and middle. No change. I'm sure the Start/Trim fuse is good because the avionics fans turn off when the fuse is removed.
Suggestions on how to proceed?
