Door facing North or South for Florida hangar?
soarak
I'm New Here
If you had a choice for a hangar with door facing south or north, which would you choose. North would be great to keep the heat away but south could see relative humidity decreasing due to higher air temp in the hangar, and possibly moisture evaporating faster after rain? What about in practice from your experience?
I'm always a fan of South. I know it doesn't matter as much in Florida, but my thought is that in the Winter, with the sun relatively low in the sky, you'll get warming sun directly into the hangar. In the summer, the inclination of the sun means the sunlight will <mostly> fall on the roof, not shine into the hangar. Again, probably a better strategy for points North of you.
Take any you can get!
I would take north facing. If it's not insulated and airconditioned, it wil get plenty hot regardless. Make sure there is a vapor barrier under the concrete. Lack of that will spike your moisture and be a much bigger issue than orientation.
Well finding out if there is a vapor barrier under the concrete could be quite difficult. The hangars were built 20 years ago. How would you find out? The only option is to tape 12”x12” plastic sheet to the floor and see if there is moisture under the sheet in a few days.
I had to make this decision when I bought a hanger in Jax, FL. I picked South facing. More sun in the Winter when you want it and less sun during the heat of the summer. In North FL, it does get cold in the winter.
Anything is better than East or West. My hangar door faces due East. Before I insulated it walking in front of it in the morning was similar to walking in front of an open oven.
Personally, I don't think it matters in the rare instance where you actually have a choice. Location (eg Pan Handle vs South Florida vs Coastal vs inland) can have a larger impact overall. My 8 years in Tampa vs the same amount of time in Northern VA has taught me that the number of days where the hangar is an absolute oven are greater in FL and the hangar never gets anywhere as cold as I saw in Manassas, at least not for any length of time. It's FL so the humidity is generally high most of the year so unless your doors seal really well (mine do not) moist salt air is an ever-present issue.
Note: My doors face South and the hangar is not insulated or climate controlled in any way (same for my Hangar in Manassas although its door faced East).
I'm in the planning stages of building a home/hangar at Love's Landing, in Weirsdale, FL. Beautiful corner lot My only choice is to have the hangar door facing East. 60x70. The door will be insulated and covered on the inside. My current hangar home in Chandler AZ has the door facing North. Definitely the best orientation as the summer sun is in a southern sweep. The garage door is south facing and the garage gets really hot.
I'm in SC and my hangar faces North. In the summer, the hangar doesn't get hot until around 1200, then pretty much remains the same temperature for rest of the day as the sun isn't shining on my doors. In the winter, the steel T-hangar, with insulated ceiling, it just about stays just above ambient temp throughout the day.
The best insulation I found for my hangar doors (1 Schweiss bifold, 1 Higher Power hydraulic) is the 2" foam board with the radiant barrier. Mount it on the inside, on top of the metal framing so it has an adequate gap between the metal skin and the radiant barrier. Went from walking by an oven to no heat rise on the inside surface of the foam. I installed it with 2 sided tape 12 years ago, nothing's come loose yet.
