Tele Radio T60TX-03STL-US hangar remote gave up the ghost. Any ideas?
DeltaRomeo
doug reeves: unfluencer
Staff member
My hangar remote sleeps with the fishes after many years of faithful service.
What are people doing these days?
Refurb online for $170. https://www.radwell.com/Buy/TELE RADIO/TELE RADIO/T60TX-03STL-US
‘Recommended by Schweiss’ modern hardware replacement is $700+
The 'clean all the corrosion' approach has been tried, and failed.
I may just end up using the key and pushing the button inside to raise. <g>.
v/r,dr
If you don’t understand the failure mode(s), you cannot hope to fix the problem(s)…
So - what’s the data telling you?
Push button. Door no open. Battery contacts cleaned. Batteries replaced. No joy.
Other two remotes work. Factory stopped making the remote 8 years ago.
Here's what I use: 3-Button garage door opener (PBS-3). Runs about $17. Remote control system PB3-DRC. Runs about $145 and includes additional PBS-3.
Works great!
Works great!
This Mel?
Encouraged at this possible solution.
Appreciate the tip (and will update when I know more),
dr
Clean the switch contacts instead - probably graphite buttons that touch across a grid - a little Iso-alcohol scrub on the pcb contacts should do the trick.
This Mel?
dr
Yep, that's it. Works great. Took almost 20 minutes to install. Of course I already had the 3-button opener, so basic wiring was already there.
Come over and take a look.
Fixed:
Completely disassembled. Internals cleaned with electronics cleaner. Works now. Nice to know there is a relatively cheap solution down the road, when it finally breaks.
v/r,dr
