auburnaviator
I don’t see this Master switch configuration listed in the manual anywhere and I’m trying to figure out why. I know the alt is controlled by the J12-11 pin on the VPX but couldn’t that pin be associated with the “up” Bat/Alt position of the DPDT switch? The “up” Bat/Alt position could be associated to one of the J2 connector 1-10 switch pins on the VPX. I’m sure I’m just missing something simple here and this isn’t listed in the manual for a reason but I currently can’t see it.
If this won’t work, is there another solution without adding a separate SPST alternator switch to the panel?
