Trim tab clamp block loaner
I made one out of two blocks and two welding rods. I think it was in the plans.
For the elevator trim assembles? Theses are just V shaped blocks to hold the shape, thought i would check around before going out and buying would just for a one time usage.
Thought you were referring to the clamps you make to shape the trailing edge of the trim tab. The blocks to hold the tabs I just cut out of scrap wood from the crate.
I have no spare wood laying around, i know its simple just figured someone may a set laying around.
If you were closer, I have all kinds of stuff that might be useful. All pretty much built out of Van’s shipping crates. Except for my little, eenie, weenie brake for trim tab ends. I also have a hardwood block for the fuse side skin bending.
Alas, you are not close. Perhaps someone is who might benefit. Otherwise, I will be donating to the dumpster over the next year or so.
