simpsonstu
Sorry folks I know there was an old thread on this, but what is the latest consensus on adding a rudder tab? So the aircraft needs a bit of right rudder in the cruise to centre the ball(Climb and descent I accept I need to do it) , so trim tab mid rudder but on the right side of the rudder as you look head on (on the left side of rudder if you look from rear), until you work out what angle to bend the tab-what do you stick it on with?
Was there a company that sold rudder trim tabs? None of the prev links seem to work?
Cheers Stu
UK
Cheers Stu
UK
