GVilleFlyer
Must I drain fuel in my tank to perform W&B, or can I subtract it mathematically from weight and moment ?
To get an accurate weight that includes however much unusable fuel your particular plane holds, it’s best to drain it. Not hard to do if you remove the sampling cock under the access plate on the bottom of the fuselage (with fuel valve shut off!), and attach a hose on a barbed npt fitting. Then drain into jugs.Must I drain fuel in my tank to perform W&B, or can I subtract it mathematically from weight and moment ?
