Yeah I have seen them, but their policy is as-is so you get a bad crank, you are out of luck. Seems like a big gamble when looking at close to $20k plus a teardown and inspection.Used Aircraft Engines
Thousands of airframe parts listings from manufacturers like Piper, Cessna, Beechcraft, Mooney, Grumman and more...texasairsalvage.com
And then who knows how much to rebuild. It might work out cheaper, it might not.
Just to close this one out. I found a mid to high time bottom (1500hrs) 100hrs on TOH IO-360-C1C from a Piper Arrow that was being parted out. It was run and checked out by an A&P and in overall good condition but had been sitting for while. It came with all accessories including the oil cooler and boost pump. I also bought the prop off of the plane C/S Hartzell with 7666A-2 blades on it. I paid $12k for the package.
