Thinking about starting a 12is this fall. This would be my second build. Just finishing up a 14. I would be buying virtually everything from Vans. Avionics, Wiring Harness, everything. On my 14 I incorporated the Wiring Harness in the build as I went. Seemed easier at the time, and it was. But reading info from Vans it sounds like you can delay the wiring till the end. Is that accurate? Just looking for the easiest process. Also, Vans kind of eludes the usual build sequence, as in Tail, then wings, then Fuselage, Finish kit, engine, etc. But what if you did the wings last? Since they are made to come on and off anyway. Would save messing with a wing cradle, that's all. When you got a wing done you could just put it on. Am I missing something?
Thanks, Jerry Kalin
Thanks, Jerry Kalin
