I'm 11 hours into phase 1 and I'm pretty sure I've completed break in several hours ago (oil consumption stabilized and I've not consumed any oil in the last 4 hours). I started to do some endurance and max range testing, and my question is if I'm over cooling my engine/oil. As a note: I don't have my fairings or wheel pants on the plane yet. Engine is a Superior IO-360-B1HD2 180hp 8.5:1 dual PMAGs & 3 blade MT Prop
The information below is just from the cruise portion of each flight, and they were performed at different altitudes (the hot day testing is for comparison).
Here are the parameters (with charts):
GPS Altitude: 4500ft
CHTs:
Oil Temp: Decreasing from 172F -> 153F over 15 minutes of cruise
Fuel Flow: 7.3 GPH
Percent Power: 61% - 62%
TAS: 130kts
I did another flight a few weeks back when we had an unseasonal heat wave and OAT was between 95 and 105. Parameters from that flight for comparison
GPS Altitude: 1500ft
CHTs:
Oil Temp: 199F
Fuel Flow: 12.3 GPH
Percent Power: 76% power
TAS: 147Kts
My question to the experts out there - do I need to do anything? Oil Cooler is attached to the #4 rear baffle, and I don't currently have any way to block air to it, but have looked into adding a shutter or some other valve.
Cold Day Testing
OAT (at altitude): 46FGPS Altitude: 4500ft
CHTs:
- Cyl 1: 323.6
- Cyl 2: 318.6
- Cyl 3: 312.8
- Cyl 4: 336.2
Fuel Flow: 7.3 GPH
TAS: 130kts
Hot Day Testing
OAT (at altitude): 97FGPS Altitude: 1500ft
CHTs:
- Cyl 1: 390.2
- Cyl 2: 390.1
- Cyl 3: 381.2
- Cyl 4: 386.6
Oil Temp: 199F
Fuel Flow: 12.3 GPH
TAS: 147Kts
