RV10. I am working on the Elevators.
In photo, instruction 6 says to put a slight bend in trailing edge of E-1001 skins so they lay down flat, references section 5. I can't find anything in section 5 specifically addressing this, it looks to me like they will/should lay flat without a bend?
- Should I bend and if so which direction?
- Looking ahead, section five uses a 3M two sided tape instead of flame seal on the trailing edge. Which should I use?
- Trying to read on this I see reference to building a home brake with door hinges, but this seems to only be used on a bent over trailed edge, not a 2 or three piece. I expect this is needed for the trim section?
