These things are buried in other threads, thought the system deserved its own thread.
I had to redo one of the few metal parts on my SeaRey (I messed up and put the Dynon OAT in direct sunlight, and I didn't like the way a couple of the mounting holes came out.) which meant cutting and repainting a new fairing. I had originally used Polyfiber Aerothane, but since it's a 2 part epoxy and I no longer have access to a booth I was stumped how to apply it. Greg, the tech support guru/jedi master at Polyfiber told me about Preval, which is a disposable, eco-friendly, refillable spray can system. You can pay too much and buy it from ACS, or Home Depot carries them at a much cheaper price.
You use it like a rattlecan, but after the first test shot I took the filter off the bottom of the intake tube and it pulled easier.
The only bad thing was after doing the primer the night before, when I went to do my test shot this morning with paint the nozzle jammed ON, sending out a continual stream of spray. In the back of my mind I could hear Richard Dreyfus saying "This is good. I was rusty on panic." as I watched dollar signs of paint getting wasted before I thought to unscrew the bottle from the spray unit, wrapped the nozzle up in a rag and jammed it in the hazmat can, where it sputtered angrily until it eventually ran out of aerosol.
I'm not sure about the finish I got yet, it doesn't look as good as what I got from the LVP gun in the booth, can't tell if it's going to smooth out as the Aerothane dries (it takes about a week for it to really cook off.), or if it was me (I thinned it out as much as I dared), or if it's the limitations of the system itself, but if you have a small repair or are happy with a ten-foot paint job, it'll do.
Preval - Refillable spray system - Spray any paint!
Refillable DIY and Pro paint spray systems. Spray any liquid for professional results. Order Now or call to become a distributor 877-753-0021
preval.com
