I just finished inventory of the power plant kit and these were in one of the bags of hardware. Unfortunately I don’t remember what bag they came out of. There wasn’t anything listed in that bag that matched these so I set them aside. Thanks
Brian is correct. Those are isolation bushings used when mounting oil cooler and radiator using the original or version 2 mounting style. The 3rd and current system is to mount to cowl. See SB-00088 Rev 2 for the change from original style to version 2. My power plant kit came with the original hardware and SB-00088 instructions and the new (now old) bracket with those same bushings. SL-00112 describes moving the oil cooler and radiator to the cowl and requires the purchase of Kit SL-00112A or B. Presumably, if your power plant kit was shipped after 9-30-2025 you have SL-00112 included. The bushings were included in a hardware bag that probably was picked and packed before 9-2025. They bushings are not now used but there are planes flying with them so somebody out there may find them useful. The original part numbers are WR4-140 and WB4-140.
