Engine's got about 160 hours on it. Whenever I stick a borescope in to have a look at the inside of the cylinder, the cylinder walls and the valves seem fine and clean, but the tops of the pistons all have what I can only describe as "white gunk" on them. I've seen other borescope pictures of engines much older than mine where the piston surface is a lot shinier and cleaner. Is this something to worry about? I must admit that when I look inside with a borescope, I'm not really sure what warning signs I'm looking for.
