So I have RV-12iS experience. However I have more time in right seat as a CFI than actual stick time doing checkouts, flight reviews, instrument practice. I fly with many people and different planes. I am stumped here... is this normal?
Observing the pilot/owner taxi. his RPM is is way high and I feel he's dragging brakes. I suggest he let go of brakes, use rudder (to the floor and if needed) reduce power. Well a few things happened. We start going left. He also pulled power back and PROP almost stopped (more on that below ***).
My questions
1) can you taxi an RV-12iS without higher power over 1800 RPM and dragging brakes?
(I get with a cross wind that would be needed but it was just past sunset dead calm. I've flown free castor planes, RV's, Grumman, understand differential braking, even a Metroliner turboprop, nose gear steering was turned off on takeoff and landing.)
2) What would cause a RV-12iS to have turning tendency landing or taxi (which is not left turning tendency from prop or x-wind)?
(Plane does seem to pull in one direction unlike RV-A models,. Gear tracking issue? One tires has a flat spot after 100 hrs. Locked it up once or twice?)
3) If an RV-12iS likes to go left or right, can you adjust that out?
(I haven't built an RV-12iS (built RV-4/-7), no toe/camber adjustment once gear installed.)
*** PROP STOP/Engine stall not focus of post, but feel free to comment. I read recommended Rotax 912iS min idle at 1650 to 1800 rpm. When cold pilots should set 2200 rpm after start, when engine is cold, for smoother ops and gearbox happiness. Not my plane but really would like to know for my own CFI knowledge. I read idle stop screws on the throttle bodies adjust idle. Factory setting may be too low. Recommended for smooth 1650–1800+ RPM to avoid excessive gearbox vibration. I can say this RV-12iS the prop stops on the ground at full idle.
My questions
