I'm building new ailerons for my (bought, not built), RV6.
Just before the chapter 11 I bought parts to build two ailerons and finally started them this winter. Unfortunately I screwed up - it went well until the last part, when I drilled the bottom spar holes too far forward and therefore too close to the bend in the spar to be able to dimple. This happened because the nose ribs were over sized and I didn't reduce them in size sufficiently (I didn't realise just how basic RV6 parts were compared to newer kits). These RV6 aileron skins were are punched, but none of the other parts are.
Womp.
At this point everything was match drilled, so I figured I'd suck it up and start again from scratch.
So, $1500 down and I have a second set of aileron parts. I've alodined the stiffeners and primed those as well as the skins, and riveted them in. I have the skeletons clecoed together with the exception of the water pipe, and a wood tool made exactly to the plans so I can get the nose ribs right this time.
So I get the nose ribs so they fit the plan perfectly (pictured prior to adjusting the water pipe attachment tabs):
As far as I am concerned, these ribs now match the plans as close to perfectly as is reasonable.
I then clamped the skeleton into the upper surface of the skin with the upper spar flange being correctly placed over the punched holes in the skin. When I wrap the forward part of the skin around the nose rib, this is what happens:
So, with the punched holes for the bottom spar flange correctly placed, the curvature of this skin is way off. Here's another angle showing the lower spar flange hole placement
It seems to me that the radius around the water pipe in the skin has been made in the wrong place. Here's a photo of the new skins with the last skins I had, you can see the radius is offset about 3/16" on the new skins when compared to the pre punched water pipe rivet holes:
New skins:, with blue lines showing the approximate beginning, end and centre of the radius:
Old skins with the same lines added:
As you can see, the radiuses are not in the same place.
If I add my outline tool to make the leading edge of the skin the same shape as the plan, then this is what I get. The lower spar flange holes are nowhere near.
And if I just try and push the bottom of the leading edge flat against the nose rib:
So, what would you do? The skins arrived with dents in the trailing edges so I'm trying to get some credit from Vans for this (no response to my emails after 2 weeks and two phone calls...) but I need them done so I pressed on with the assembly. I can't wait for another set of skins to arrive, and the set I ordered back in 2023 were also dented although I didn't mention it and just pressed on with the work. Annoyingly, those skins were actually bent correctly!
Right now, all I can think of is to take a piece of tube or bar and drill holes in it so I can screw it to another piece of tube through the pre punched rivet holes. I could then roll the radius along a bit, but that might make the skin try to concave on the lower surface of the aileron. What does VAF think? I'll do anything to avoid having to make a third set of ailerons!
Womp.
