I think it was Churchill who said It is better to keep your mouth shut and look like a fool than open it and prove it, but Churchill was a Lord of the Admiralty, not a kitplane builder.
I need to run some 20 ga power and ground wires to the master solenoid and starter contactor for a Rotax 914, the best way to support/run them is to lace them against the ground wire from the battery-engine. If the ground wire was a normal size 12-22 ga I don't think I'd have much qualms, but running them next to a 4 ga ground wire makes me wonder if it's a good idea. (I know, electrons can't pass though Tefzel. Can they?)
The battery ground runs aircraft left->right from the battery to the engine, the 20 ga wires run from aircraft left->right from the sources to the contactors.
Thoughts? Am I ok to do this, or should I find a different way to run them?
TIA
TIA
