Tom,Looking for recommendations for a good set of jacks for an RV-4. Also curious what methods others are using to secure the tail down. Mine wanted to come up with the mains last time I changed a tire. Thanks.
I can find the ram jack, but not the stand. Where is this from?
welded from spare parts.I can find the ram jack, but not the stand. Where is this from?
Dangwelded from spare parts.
You know, I've always wanted to learn to weld. But right now, I'm just trying to get a plane in the air.Oh, come on! Perfect project to learn a new skill, if you don't know how already!I had a friend who was hesitant to jump into his 4570 welded steel fuselage for his Steen Skybolt. Decided that the best way to learn was to build a steel bookshelf! It got pretty huge! Interesting to look at his initial welds and how his skills improved over the course of the non-flying bookcase! His welding on the fuselage was excellent, from his developed skill! You might find, as I have, there are suddenly many things that need to be welded up or heated that, without my welding tanks (old but still good technology!), would have had to farm out!
Didn’t learn to weld until I‘d built six planes and maintained many others…so feel no pressure Bob!You know, I've always wanted to learn to weld. But right now, I'm just trying to get a plane in the air.
https://www.ebay.com/itm/124177700540 for the jack stand. It is cleverly disguised as a pipe stand.
View attachment 111250View attachment 111251
This is the 20" version. Some versions are too high. Cut the "V" off the top and drill into the top of the threaded part to make a dimple to catch whatever you use to screw into the wing tie down. I use these on the wings. They come from aircraft spruce P/N 05-12379.
The outside diameter without the treads is 1 1/8". The blocky threads are about 1/8" making the overall diameter 1 3/8". The cones are 3/4" diameter. I drilled a socket in the top of the post using successively larger bits with each going in less than the previous one. The largest bit I used was 3/4" but drilled in just enough to countersink the edges of the hole to almost match the diameter of the cone. The cone then sets in the socket almost up to the shoulder.Once you cut the top off, do you know what the outside diamater of the post is?
