We’ve had this WW-330 sitting in its crate on followed for some time now - I hadn’t mounted it simply because props get in the way when you;re working. But yesterday it was either mount the prop or do more work on gear leg fairings, so I made the “fun” choice, called a couple of neighbors and in ten minutes the prop was on. I had previously fit the cowl using the “EZ-Cowl” tool, and now am doing just a few more tweaks to get the clearance where I want it - then I guess it will be back to gear leg fairings…..
