As the title implies - I'm considering adding a G5 to the Rear cockpit so the pax has a flight display to see and/or fly off of. I often fly with other pilots and while they can see my G5 over my shoulder - its not ideal to fly that way from the back seat. I don't want to add an entire extra EFIS display back there so I thought a G5 would be ideal due to its compact size.
Couple of questions.....
1) Does a 2nd G5 require its own magnetometer? Or can I tie into my existing one back in the tail?
2) Is it possible to tie into the pitot/static lines? Or do new ones need to be run?
3). Has anyone done a similar install like this in the back of an RV-4/8. My plan was to mount it to the back of my seat or to the roll bar itself. Any tips, tricks, lessons learned??
